1996 855 20v Code P0121 LH 3,2 Ideling at 1500 rpm
- Year and Model: Many Volvos
- Been thanked: 76 times
Are you sure you have the Jetronic system? By '96 I thought Volvo had completely phased out the LH 3.2 and gone with the Motronic 4.3. The quick way to tell is to pull the ECU box cover and see how many modules are plugged in. The LH 3.2 had two engine modules and a third module for an automatic transmission if your car is so equipped. The Motronic is a single module and then there would be a second module for the automatic transmission - again, if so equipped.
If you do have the LH 3.2 I don't know what reader might work, I have never seen one that had OBD-II capability. How was the current code (P0121) read?
The P0121 code is an OBD-II code and it is different than the DTC code 1-2-1 that you read with the flasher unit. DTC code 1-2-1 is a MAF sensor code and P0121 is a throttle position sensor code. They don't interchange number for number.
I have seen a dirty IAC valve cause a MAF code and a high idle on the LH 3.2 but a missing MAF signal will do it as well. Does anything change if you just unplug the MAF sensor?
Hopefully Julenissen arrives safely! Have a Merry Christmas.Orlille wrote:Thanks..will try to unplug MAF sensor tomorrow, 11:08 PM here right now, and santa is on his way.
It won't hurt anything but it may stall. If it does nothing (no change) at all then the MAF is probably bad. It will illuminate the lambda light and set a code but that is easily cleared. I have run the LH 3.2 without the MAF plugged in and the throttle response is odd and the idle tends to surge a bit without it.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Sounds like fast idle for warm-up RPM, does temperature indicator show normal operation? Perhaps the Engine Coolant Temperature sensor is bad?
Current Volvos:
- 17 Replies
- 3180 Views
Last post by jonesg
- 746 Views
- 1634 Views
Last post by flippedBit
- 1676 Views
Last post by Clemens
- 3122 Views
Last post by jbkeene
