Is a 1999 volvo s70 glt a expensive car to maintain?
hours
Year and Model: xc90 2009
Post by hours »
like im 17 i make around 200$ a week so if i bought a 1999 volvo s70 glt with about 140000 miles on it is it gonna be expensive like to get the car fixed is it expensive or around average? my father said it is as much as a bmw?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Stay away unless you can fix things yourself.
rspi
Post by rspi »
Same car just a little older.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
Agreed. I got my 2000 V70XC when I was 17 in college and it had 115K on it with things already wrong. This car would be in the dump by now if it hadn't been for this forum and others like it. As long as nothing major (e.g. engine, trans, steering rack...) goes out on it, you can maintain it yourself for far less than taking it to a shop. If you're not ready to get your hands dirty and spend some time under the hood, then I'd avoid.
PS. rspi, love your videos!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Has thanked: 1500 times
Been thanked: 3810 times
Hours...I'm not sure how available parts are in China, that will depend on where you are.
If you are from SoCal, no problem.
Please make sure your posts conform to posting guidelines in the sticky above.
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
The '99 also has the electronic throttle module to compound potential problems.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Sell it, sell it now.
85 GLH, 367 whp
00 Insight, 72 mpg
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Your father is a wise man. If you don't have some ability with hand tools -- or the willingness to learn -- an older Volvo will bleed you dry on a student budget. At 140,000 miles, you are going to be coming up on needing to renew the suspension if it hasn't been done already. At U.S. prices with quality components you are looking at about $600 in parts alone to do that job. It is several hours of labor if you are doing it by yourself (ideally with a helper), but not essential.
It would be nice to have a mechanic's creeper -- again not essential-- a set of ramps, a quality jack and some jack stands, as well as a decent set of mechanic's tools. A covered garage with a cement floor is also nice for working on the car, but again, not essential. I also consider an OBDII scanner (aka a code reader) to be an essential tool for owning these cars.
Do you have the time and inclination to spend time searching this forum and others like it (although this one's usually the best) to post inquiries and wait for responses and to work through repair posts?
I'd budget about $1,000 U.S./year for repair and upkeep if you are doing the work yourself -- several times that if you are paying a mechanic. Another important consideration is your access to sources of used parts - aka pick-and-pulls, junkyards, scrapyards, auto recyclers, etc. Without the ability to come by some parts used, and the time to pursue them (i.e., remove them from donor cars if necessary), you'll be stretching your budget even further.
Also, the GLT is a turbo model. The turbo adds an extra layer of complexity -- which = more $.
Based on what you've said so far, I'd be looking for a Toyota or Honda if I were you.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Ben850
Been thanked: 7 times
Post by Ben850 »
Like, don't do it..
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Been thanked: 466 times
Post by cn90 »
Every used car, especially those sold for $2000-$4000, with > 10 years old and > 120K require some work.
Even Honda Toyota need some serious work such as timing belt, water pump and all that jazz...
The Volvo is no different in terms of cost. It is cheaper to maintain my Volvo than my Honda.
1999 was a "bad" year, if you get over the ETM issue then you are OK.
My approach to a used car: if my budget is $4000, I don't buy a $4000 car. Instead I buy a $2300 car and put in $1700 parts (such as strut, control arms, tstat, timing belt/pulleys, radiator etc. etc.). This way by the time I reach $4000, it is a very nice machine to own.
