96 850 GLT Front Wheel well liner
joe_pinehill
- Year and Model: 850 1996
Are the liners in the front riveted in? I know on the right side, a couple screw/fasteners allow you to fold the flap back to access the crank pulley. I wanted to fold the left side back, to access the carbon filter, but it looks like its riveted on. Are they common blind rivets?
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
joe_pinehill
I found one post that talks about pop rivets. I guess simply drill out and replace with common steel pop rivets?
https://www.matthewsvolvosite.com/forums ... p?p=330731
96 850 GLT
- Has thanked: 312 times
- Been thanked: 818 times
You have to drill them out, or just pry a bit with a screwdriver then nip them off. I have also used those push-in plastic fasteners as a replacement, they are very easy to use and work great.
Like these:
joe_pinehill
erikv11 wrote:You have to drill them out, or just pry a bit with a screwdriver then nip them off. I have also used those push-in plastic fasteners as a replacement, they are very easy to use and work great.
I like the idea of the push in plastic retainers, less chance of corrosion. I'll look for thin retainers at NAPA.
96 850 GLT
joe_pinehill
I would have thought the OEM rivets would be stainless. Aluminum rivets into steel can cause galvanic corrosion. A wheel well is a hard environment, wet, salty.
96 850 GLT
Ben850
- Been thanked: 7 times
Yes, that is one of the few areas I have seen, and repaired rust on 850 fenders for my cars.joe_pinehill wrote:I would have thought the OEM rivets would be stainless. Aluminum rivets into steel can cause galvanic corrosion. A wheel well is a hard environment, wet, salty.
I still use those rivets though to attach the front mud flaps.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
joe_pinehill
thanks for the photos. Rather than drilling out, I was thinking of carefully grinding the head of the rivet with my Fordom tool and carbide cutter. I have better control with the Fordam.
96 850 GLT
- 1320 Views
Last post by prendrefeu
- 12 Replies
- 1427 Views
- 701 Views
Last post by Samba
- 2897 Views
Last post by polskamafia mjl
- 753 Views
Last post by Andrew Vanis
