1999 V70XC I'm stuck - I need ideas. Topic is solved
ECU Failure in a '99 V70-XC
- misha
- Has thanked: 155 times
- Been thanked: 432 times
5 speed advantage.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Lots
- Been thanked: 128 times
OK so the challenge to '99 V70/S70 owners is to buy a Vol-FCR setup and tell the interface it's a '98......Lucky should see a steady stream of customers from this one.
Almost every time I use my OBDII bluetooth adapter (ELM327) on my '00 V70 I get at least 2 or 3 cranks before it starts and then after reading with Dice/Vida it has an immobiliser code stored.
Otherwise first crank starting every time..
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
I know how you feel Lee. I went through EVERYTHING on my 94 850. I replaced almost every sensor, then I bought a used ECU on ebay for $50 and started right up.
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Great news!Ozark Lee wrote:At long last the saga is over.
I shipped the ECU and the parts car ECU to Lucky and had him clone the "new" car into the parts car ECU. Other than the battery being totally dead after months of being parked it starts first time and every time!
I have never had an ECU fail intermittently like that. For that matter, I have never had an ECU fail at all.
I sure am glad to have this one in the done column and it is just in time for the predicted snow storm.
Who is Lucky btw?
BMW 540i 2002
S70 Base 2000
- Year and Model: Many Volvos
- Been thanked: 76 times
Lucky (Robert Arnold) runs ARD Tuning and they specialize in performance modifications to Volvos. He was with IPD for years and then a couple of years ago - it may have been a bit longer - he started ARD.Who is Lucky btw?
While he specializes in performance modifications to the ECUs, he was also able to clone my stock Bosch ME7 module into another stock ME7 module since the '99 and on cars have the entire identity of car programmed into the ECU and the other CAN bus modules. On the newer cars you can't just swap out one module for the other since all of the immobilizer codes are embedded in the module that was originally in the car.
Even with me sending the module in right before Christmas they turned it around quickly. Good people and good service.
- Been thanked: 4071 times
misha wrote:5 speed advantage.
rocky_mtn_man
- Year and Model: XC70 1998
This was 10 years ago, but did you try replacing the fuel pump relay? That can cause a no-start, especially in cold weather.
- 11 Replies
- 2548 Views
Last post by 98v70dad
- 1322 Views
Last post by volvonyc
- 4375 Views
Last post by vtl
- 6417 Views
Last post by CedBobKing
- 19 Replies
- 1266 Views
Last post by bskeels
