1998 V70 T5 Headlight Reflector Questions
This topic is in the MVS Volvo Repair Database » Cleaning Headlight Reflectors
jbkeene
Year and Model: 2000, S80, NA
Post by jbkeene »
like chrome engine paint?
Roadrunner
Year and Model: 850 GLT 1993
Post by Roadrunner »
I am not sure about the in side reflector. but to clean the out side plastic, one can use regular tooth past and a buffing cloth. Just keep the tooth past damp. As for the reflector inside has any one ever tried to use chrome paint or to electrostatic a new lair of Alumnae or some other metal that can be polished?
1993 850 GLT 300,000 miles plus and still going.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
The reflectors on my daughters car are so bad that we often question if the lights are even on. So, I have started the hunt for junk yard replacements. I look into the lenses and most look ok. Anyway, I decided to pop the lens loose and take a peek at the reflectors. On every light (about 10 so far) the reflectors look damaged. Kind of like dried up lake bed mud. I'm still on the hunt.
I can't imagine that all of these are as bad as our lights but they can't be good.
Our car has had chipped and cracked lens that probably allowed dirt and moisture in, the begging of the end.
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
I tried the chrome paint on a set of headlights from my old maxima.
Now it would probably be better than absolutely no reflective surface, but overall it didn't work. It just isn't reflective enough.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
rspi
Post by rspi »
Video example of a dim headlight.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Poilshed 1mm aluminium sheets cut to size and sealed with clear craft spray has worked for a friend of mine. Don't know how long it will last.......
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
If anyone has a source for rechroming plastic I have a lens available.
Ugly and chrome has evacuated
villagepc
Year and Model: 98 V70m | Stage III
Has thanked: 3 times
Post by villagepc »
If i had more time and energy, I'd try that new water chrome / spectrachrome system.
http://www.sprayonchrome.com/
stuff sure looks like a lot of fun
____________________________________________
1998 V70 T5M R Clone | IPD / ARD Stage 3
2008 S80 3.2 - not too shabby
1991 740 Turbo - 2.5" lift, 100% madness
MarinerMan
Year and Model: 1999 V70 N/A
Has thanked: 6 times
Been thanked: 8 times
Post by MarinerMan »
The reflective material is actual chrome, not plastic. They adhere it to the plastic by covering the plastic with an electrostatic boding surface, much like the first step in powder coating. Then high voltage is applied to a piece of chrome alloy in a vacuum chamber. The piece offgasses, and is drawn to the charged coating on the plastic. It is hard to do at home. If you had a friend who had a CNC mill, you could make aluminum or stainless blanks and then do a chemical bath electroplating with chrome or nickel.
MarinerMan
