2001 V70 Dome Lights Will Not Go Out
79lilred
Year and Model: 01 V70
Post by 79lilred »
Well, some times they will, but most often not.
Courtesy lights in the floor at your feet work fine - they turn off after shutting the door and after a short delay. But it's hit and miss whether the overhead dome lights will go out. The previous owners solution was to simply unplug the overhead lights - which is the way I have them now.
Since the lights in the floor work fine, I'm assuming the problem is not the infamous microswitch in the door latch.
Any ideas will be much appreciated!
draser
Year and Model: 2005 S60 2.5T
Post by draser »
Unless the door switch has 2 sections, which will have to be verified with a wiring diagram.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
79lilred
Post by 79lilred »
seems I recall reading some place that is could have something to do with the alarm system????? Before I bought the car, it had been in multiple wrecks due to being used by teenage brothers
draser
Post by draser »
Looking at wiring dia, there's a dome control module that controls dome light. I believe it's located at front of car where the front dome ligbts are and sunroof switch is. I'll try taking that bezel out to get to connector and spray contact cleaner into it.
bigbrain
Year and Model: v70 D5 2003
Post by bigbrain »
I had the same symptom on my 2003 V70 when the interior door pull broke...of course it was at the end of a very long day rebuilding the front suspension...I was just getting out to lock up the car!...I was just about to leave the handle for another day when I spotted that the dome lights were still on even with the doors locked! Taking the door card off I could see that the handle mechanism is quite weak and had popped out and busted....I made a small metal bracket and secured everything with a couple of self tappers...figured this might help as my symptoms were the same but the cause was obvious in my case.
79lilred
Post by 79lilred »
bigbrain wrote:I had the same symptom on my 2003 V70 when the interior door pull broke...of course it was at the end of a very long day rebuilding the front suspension...I was just getting out to lock up the car!...I was just about to leave the handle for another day when I spotted that the dome lights were still on even with the doors locked! Taking the door card off I could see that the handle mechanism is quite weak and had popped out and busted....I made a small metal bracket and secured everything with a couple of self tappers...figured this might help as my symptoms were the same but the cause was obvious in my case.
Very interesting!
My drivers door, inside door pull also broke. I used epoxy and put it all back so it is something to grab. But having trouble understanding how the plastic inside door pull can affect the dome lights .....
79lilred
Post by 79lilred »
draser wrote:Looking at wiring dia, there's a dome control module that controls dome light. I believe it's located at front of car where the front dome ligbts are and sunroof switch is. I'll try taking that bezel out to get to connector and spray contact cleaner into it.
I would guess that this "module" is part of the dome light/sunroof switch assembly. I grabbed one (the entire assembly - lights/switch et al - out of a junkyard and it does exact same thing.
draser
Post by draser »
Door switches for second row control the foot well lights? If not, I'd check them out make sure they work.
bigbrain
Post by bigbrain »
Yea...it confused the hell out of me too. On mine the pull handle on the inside went pop...I could still close the door and lock the car but the lights stayed on....it was very annoying. When I pulled the door card the back of the mechanism had popped out...I could pop it back in but I could also see it would likely come straight back out so made up a small bracket out of some 1mm steel I had in my scrap bin and job done and everything was back to working. When I saw your post I recognised the symptoms so figured I'd better mention it just incase.
79lilred
Post by 79lilred »
bigbrain; Door "card"? Is that the inside door panel? You brits and your terms! ;-) I have a good friend who lives in West Midlands.
The dome lights were acting up long before my inside door pull broke. But I may pull the panel back off and see if I can figure out what exactly your are talking about.
draser; not sure what you're asking. When I open a door, the foot well lights come on. When I close the door, the foot well lights gradually dim and go out. Dome lights stay on.
