... without MVS Mavericks.
Both our cars are running CEL free for few weeks, no visible fluid leak. Wow! Thanks you ALL for premium gas at $2.239/gallon.
But there is a clear, loud metal to metal knock at morning start -- the moment before engine start after the crank. It was once in a while, but occurring frequently since this Fall.
This morning first two tries engine cranked but did not start. Third time, it cranked, then one metal-to-metal knock, and started -- it doesn't take more than few seconds for engine to start.
Any thoughts?
2001 V70XC - VIDA DiCE is useless...
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Assuming you have the correct oil and level - the knock is high pitched and coming from top of engine or deep and from bottom? Or is it coming from engine or exhaust? More detail needed.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
xHeart
Engine oil and filter replaced around thanksgiving. I will check the level again.draser wrote:Assuming you have the correct oil and level - the knock is high pitched and coming from top of engine or deep and from bottom? Or is it coming from engine or exhaust? More detail needed.
Not a high pitch, suspecting lower engine.
draser
Lower engine knocks are caused by connecting rod bearing wear and it's pretty rare, unless a catastrophic event took place - lack of oil or pressure or engine has lots of miles. Did not see a mention of low press. light. First effect is low oil pressure due to larger clearances at conn rod bearing. So for peace of mind you could check oil pressure. I'd also investigate more just to make sure of location.
xHeart
There is no CEL at this time.draser wrote:Lower engine knocks are caused by connecting rod bearing wear and it's pretty rear, unless a catastrophic event took place - lack of oil or pressure or engine has lots of miles. Did not see a mention of low press. light. First effect is low oil pressure due to larger clearances at conn rod bearing. So for peace of mind you could check oil pressure. I'd also investigate more just to make sure of location.
Would connecting DiCE and reading oil level and sender data over VIDA provide any clue?
I am assuming engine idles for taking this reading?
I will ask girls to play echolocation game each morning this week.
Many thanks.
- Has thanked: 1611 times
- Been thanked: 4072 times
Sounds like time to break out the colour matched garden hose and isolate
- Year and Model: Lots
- Been thanked: 128 times
Oil pressure sender on block is not a variable device. It's just a short to ground with no or low oil pressure.
You need a guage type sender tapped in to the block.
xHeart
The metal-to-metal knock is absent, or I did not hear.precopster wrote:Oil pressure sender on block is not a variable device. It's just a short to ground with no or low oil pressure.
Is there a helpful reference for "gauge type sender tapped" Mike, -- perhaps loan-a-tool at Autozone or likes?
Oil Pressure Sender photo from IPD's..
xHeart
Thanks for the pointer.methdon3 wrote:I got my oil pressure tester for 25 bucks at harbor freight. the loaner at pepboys was the same price.
O'reilly loans one with multiple connector types.
- 16511 Views
Last post by xiaofei204716
- 10 Replies
- 19183 Views
Last post by jonesg
- 7154 Views
Last post by Klem
- 10769 Views
Last post by jonesg
- 9 Replies
- 5961 Views
