1999 V70XC Transfer case removal
2JUNEJUNE
- Year and Model: 1999 VOLVO V70XC
Please find time to answer my question... I have a 1999 V7XC. Can I eliminate the transfer case and use a FWD axle? Do I need to remove also the protruding cylindrical piece at the passenger side of the transmission which is present when you detached the transfer case? Thank you.
- Year and Model: Many Volvos
- Been thanked: 76 times
Not really.2JUNEJUNE wrote:I have a 1999 V7XC. Can I eliminate the transfer case and use a FWD axle? Do I need to remove also the protruding cylindrical piece at the passenger side of the transmission which is present when you detached the transfer case?
The collar that goes between the transmission and the transfer case is a seal surface and it must remain in place to seal the transmission. If you were able to fabricate something to hold the collar in place you could remove the transfer case and even use your old axle. Without something to hold it in place the collar would simply fall off and all of the transmission fluid would wind up on the ground.
Someone clever really needs to come up with a block off plate the incorporates the collar or - even easier - a collar retainer that would set screw onto the axle. It would be really easy to make but it would take someone with a metal lathe.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I have a lathe and can fabricate something, but I haven't really looked at the design. Would this be a retainer type thing that holds the collar in place so it doesn't slide out when the BG is gone?
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Been thanked: 504 times
My understanding is that: the right axle passes through the Transfer Case.
So if the collar is stripped or the angle gear is bad, you can convert to FWD by:
- Removing the center driveshaft (that goes from TC to the Rear Diff)
- Since the Right Axle passes directly through the TC, you will be running on only 2 FRONT wheels.
That is pretty much correct unless you have a situation like Robert's where the angle gear itself, and/or its housing, are broken into pieces.cn90 wrote:My understanding is that: the right axle passes through the Transfer Case.
Jack Rock
- Year and Model: 1998 V70R
I found a suggestion on another site when I removed my gear case that used two worm gear clamps (hose clamps) connected together so the gear parts are opposite each other. The gear clamps are installed on the axle up against the collar. Sounds cheesy but it worked, didn't drip a drop for years. I inspected it a few times and found the clamps were slightly worn down on the edge where it touched the collar as the axle and the collar spin opposite to each other. I just put some grease on it.
1997 850 T5 (gave up at 324,000km)
1998 V70 R AWD (gave up at 296,000km)
1998 S70 T5 (total loss - in a parking lot!)
1999 V70XC
1975 VW beetle
1960 Empi Sportster Dune Buggy
1999 V70XC
1975 VW beetle
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Mine is a mess but I was able to get it running on 2WD. I had to tie the rear collar from the angle gear back against the exhaust, so the limp shaft flange wouldn't rest and spin on the steering rack.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
Do you have any diagrams/pics of the drivetrain for the 1998 V70XC? I'm running on FWD right now on my '98 Volvo V70XC and I want some pictures and diagrams for reference as I'm getting ready to try to make this V70XC AWD again. Thanks.rspi wrote:Mine is a mess but I was able to get it running on 2WD. I had to tie the rear collar from the angle gear back against the exhaust, so the limp shaft flange wouldn't rest and spin on the steering rack.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- shiloh51933
Here's a diagram of a 1998 Volvo V70xc transfer case.
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
I documented my removal here. I think that bracket is likely overkill, as there is no sign of that collar ever moving after it was bonded to the transmission with loctite. The install has 4-1/2 yrs, and over 60,000 miles on it now. I'm pretty sure the FWD axle will not fit due to interference with the collar.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
- 750 Views
- 450 Views
Last post by jonesg
- 2048 Views
Last post by FLXC90
- 15 Replies
- 3634 Views
Last post by shiloh51933
- 2901 Views
Last post by MoneyPitC70
