98 V70 non-turbo PCV system replacement
- Has thanked: 311 times
- Been thanked: 818 times
Copy that. With these 1/4 drive tools the bolts are easy.Ozark Lee wrote:I have always done just fine with a combination of a 1/4" drive ratchet, 10" extension, a 3" extension, a swivel joint, and 10mm deep socket. ...
Oh of course, great idea, I will have to try that. The floppy swivel is the one part of the IM removal that is still slightly annoying.Ozark Lee wrote: ... I use electrical tape on the swivel joint to give it a bit of rigidity to get to the joint on the bottom left.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
+1 on Lee and Erik's comments. Never needed any wobble sockets to do this job.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
98v70dad
- Year and Model: 98 V70
You can never have too many tools. I found a 1/4 drive wobble extension set at Home Depot for $15. I think I'll get that and a flex joint. I already have some regular 1/4 drive extensions. Thanks for all the advise. I honestly did think Home Depot or lowes would have a wobble set at a decent price, so I didn't look before posting.
- dosbricks
- Been thanked: 4 times
The wobble extensions are great--smoother more accurate application of torque than a swivel joint when you are tightening down bolts. They can not achieve as much angle but usually just enough.
http://www.harborfreight.com/9-pc-wobbl ... 67971.html
These are made in Taiwan and the quality is surprising. BTW, I don't work for H.F.
98v70dad
I am planning to replace the intake manifold gasket. It occurred to me yesterday that all of the step by step instructions I've looked at have you loosening the bottom row of bolts and swinging the manifold to the right out of the way. This isn't going to work if you replace the gasket.
What do people do with the maifold if you want to replace the gasket. The obvious answer is to lift it out of the car but maybe there's an easier way and easier is better.... what advice do you guys have ........?????
- Been thanked: 504 times
https://www.matthewsvolvosite.com/forums ... hp?t=53448
https://www.matthewsvolvosite.com/forums ... =1&t=28334
https://www.matthewsvolvosite.com/forums ... hp?t=28487
98v70dad
So here's my progress today. My wife had people over this morning so I didn't start working until 1:00 PM. I made a lot of progress....got the throttle body off. got all the necessary stuff disconnected, removed and loosened the intake manifold bolts, removed the dipstick tube, etc and then it got dark. So I called it quits for the day and went inside to clean the throttle body,
So...everything went according to plan EXCEPT I had one surprise. There is no flame trap in my car. Maybe someone removed it long ago. ...don't know. Anyhow, where the 5/8 heater hose terminates on the drivers side it goes into a plastic elbow about 4 inches in diameter near the mass airflow sensor. There is a restriction in the line that is 5/16 in diameter here instead of the flame trap.
What do you folks think I should do with this restriction, leave it alone or drill it out to a bigger diameter? It doesn't make a lot of sense to me to increase the hose diameter to 5/8 dia. with heater hose and then choke it down with a restriction to 5/16 dia. at one end.
If you encountered this situation on your car please tell me what you did with it and how well it worked.
- Year and Model: Many Volvos
- Been thanked: 76 times
There really isn't (shouldn't be anyway) that much flow so the smaller diameter works just fine.
- 1580 Views
Last post by hanzbe420
- 20 Replies
- 4880 Views
Last post by erikv11
- 850 Views
Last post by SonicAdventure
- 20 Replies
- 3135 Views
Last post by Lordflash
- 26 Replies
- 3767 Views
Last post by Ringo
