1997 Volvo 850 - CO2 buildup - pulled over to safety
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
FLXC90 wrote:yes, check for any cracks in manifold, check all flanges. Was the downpipe w/flex joint changed? joint could be a major candidate, hidden under braided sheath.
The manifold replacement was one piece, from exhaust to cat. I will look at the accordion like joint where it meets cat. Here is more on manif repair https://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=60494
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Most cars intentionally leak 10-15% fresh air into the car past the recirculate flap. They are required to do this by some US law.
'98 S70 T5
2016 Chevy Cruze Premier
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
I think this may work, slightly restrict your exhaust pipe to create back pressure. Shoot some SeaFoam through the intake pipe. SeaFoam will create mucho smoke and with exhaust slightly restricted any exhaust leak will have smoke coming out.
xHeart
Post by xHeart »
Starting to undo exhaust manifold.
Prep note: do I use high temp lubricant (same as spark plug one) or thread locker?
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Does that mean it failed "sea-foam smoke test"? where did you find cracks or leaks?
Current Volvos:
xHeart
Post by xHeart »
kahl wrote:...
Making it an MLK Day project -- an early morning task.
Is there a step by step for this procedure, kahl.
would it be like seafoam sucked-in at the intake vac tree under the throttle cover -- 1/3 bottle?
would putting a paper cup over the tail pipe opening adequate restriction?
kahl
Post by kahl »
Anyway to get the SeaFoam into the intake manifold. I would just partially block the exhaust, maybe a damp rag. Just enough blockage so exhaust can leak. The spray can SeaFoam comes with that funky "U" shaped pipe.
FLXC90
Post by FLXC90 »
This isn't to clean the valves, so all you have to do is get the seafoam in there. yes siphon into intake at vac tree works well. You won't need much, maybe a few ounces, shut off and let sit, prep your exhaust obstruction, and start back up. Will you have a helper available? just a ignition switch operator would help a lot, since you can't be in two places at once. (in and under car) I guess a remote start if you have it would suffice. And also, you could probably rubber band a damp rag across the tailpipe, it would still run, but add enough backpressure to make leaks evident. This would be a fun video to watch!! :lol:
Current Volvos:
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
If you are getting CO in the vehicle then you have an exhaust leak up front or exhaust leak further back AND a leak in the body. Recirculate being on increases the likelihood of external gases coming in as it reduces cabin pressurization from fresh air inlet in high pressure area from being pushed in through HVAC system and out through the vents in lower rear quarter panels behind bumper.
Air mix is not a direct path to fresh air. Air Mix on 850's is air from evaporator that is sourced either fresh or recirc but is directed through a passage where it can't pass down to go through heater core.
Airflow is: recirc/fresh air housing -> blower motor -> evaporator -> heater core -> air distribution housing -> passenger compartment. The heater ore path can be metered from zero air flow to 100% airflow
