Leak on Drivers side floor rug
sisterocean
Year and Model: 2007 V70
Post by sisterocean »
Anybody have a damp rug? Not sure if its coming from windsheild or underneath car? For sure its coming from rain? Any comments appreciated
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Last time I had damp carpet on the drivers side it was the heater core leaking. Does the wet smell like antifreeze?
Tobers
Year and Model: 850 wagon, 1997
Post by Tobers »
x2. That's what mine was. Seems to be a common problem. If it is, replacement isn't too bad:
sisterocean
Thank you so much. It is probably whats wrong. Learning way more than I wanted to. Car is 16 yrs old
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
Or the drain tube from the heater box is disconnected
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Or the sunroof drains are clogged
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
...or draining holes on both sides on front of the car by the windshield are clogged.
If it's from a rain or a car wash that's it.
Open the hood and you will see two draining hoses on the left and right side of the plastic shield under the wipers.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Been thanked: 504 times
Post by cn90 »
kahl wrote:Last time I had damp carpet on the drivers side it was the heater core leaking. Does the wet smell like antifreeze?
1+,
O.P, check your coolant reservoir level first.
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
As you can see, there are multiple options (they covered every single one)
A good place to start would be to decide if it is water or coolant. wipe/touch carpet with your finger and dab onto tip of tongue: coolant is very bitter and doesnt take much to taste it on tip of tongue. If bitter: heater core. If water: coming from somewhere else.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
humbertoflores63
Year and Model: 1995, 97, 98
Post by humbertoflores63 »
Check the location of the cabin filter, right by outside corner is drain. Make sure to clean this first.
