1986 240 DL Fuel injector connector issue
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
mhgreen wrote:"new" engine wiring harness.
Fix what needs to be fixed...Turbos have wiring harness issues, due to heat, but NAs last much longer.
mtd240
Year and Model: 2007 XC70
Has thanked: 23 times
Been thanked: 7 times
Post by mtd240 »
mhgreen wrote:I think I am going to look into acquiring a "new" engine wiring harness. There is a lot of deterioration on mine, and from my research this is a common issue from '85-'88
You can buy a brand new harness here, for ~$400. Good deal, and probably better wiring than OEM, but I don't think it is necessary in your case.
Did you peel back the wire loom/cover/whatchmacallit to look at the actual wires going to the injector connector in question?
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it :lol:
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
mhgreen
Year and Model: 240 DL 1986
Post by mhgreen »
No, I didn't want to mess with them more than I had to. I wrapped whatever was exposed in electrical tape and left them alone.
“Some cannot loosen their own chains and can nonetheless redeem their friends.”
rgk
Year and Model: Gray 88 245
Post by rgk »
Your injector resistance should be 16 ohms. Set your ohmeter to the closest setting without going over (mine, for example has 200, 2k, 20k, and 200k and I would thus choose 200), and put one probe on each injector terminal without letting them touch together.
Yes, the injectors can turn. Yes, this sounds like a connector issue. Perhaps you can find a connector at a junkyard and splice it in. But first, have you tried simply cleaning your terminals on both ends?
rgk -- was dickdeadly
mhgreen
Post by mhgreen »
rgk wrote:Your injector resistance should be 16 ohms. Set your ohmeter to the closest setting without going over (mine, for example has 200, 2k, 20k, and 200k and I would thus choose 200), and put one probe on each injector terminal without letting them touch together.
Just tested the fuel injectors. Each injector registered at 16.3 on the multimeter.
rgk wrote: Yes, the injectors can turn. Yes, this sounds like a connector issue. Perhaps you can find a connector at a junkyard and splice it in. But first, have you tried simply cleaning your terminals on both ends?
I have cleaned the terminals, yes. I am avoiding replacing the entire wiring harness, so I am interested in "simply" replacing the connectors themselves. That being said, I am not familiar with splicing, soldering, etc. This is where I would need some guidance.
93Regina
Post by 93Regina »
mhgreen wrote:This is where I would need some guidance.
Get some heat shrink butt connector
mhgreen
Post by mhgreen »
Great video. Thank you. I ordered replacement connectors on Ebay, and I plan to do this job soon. I was wondering… Is there a way to use the multimeter to test the connectors for resistance?
mhgreen
Post by mhgreen »
I replaced all the fuel injector connectors using heat shrink butt connectors. I now can move the connectors/wires and the car doesn't change it's idle or begin to run rough.
This was my first experience splicing, crimping, etc. I am glad I now have the tools and knowledge for future electrical work under the hood. Thank you all for the guidance here.
rgk
Post by rgk »
YES! Congrats.
