On the basis of the single install I have done (grin), I'm pretty sure you need to have matching firmware in the DiCE to go with the version of VIDA you are running.
I did the firmware refresh away from the car by providing 12V power through the OBD2 connector. It went smoothly.
VIDA and DICE issues
mrscullini
- Year and Model: 05 XC70, 08 XC70
just got my dice unit and having similar issues to those described here. vida recognizes the dice unit but i'm not able to interface with the car. i'm running fw 5.6.2, is this an issue? i'm also running the 2012b image on vmware. please help.
mrscullini
is that my best hope? are most running xp sp3 on a dedicated machine? i got vida 2013A with my dice unit.vtl wrote:Get Windows on a bare metal hardware, not VM.
so the fw is OK?
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Yeah, your host OS or hypervisor can't do a fully transparent USB bypass to a virtual machine.mrscullini wrote:is that my best hope?
I run 2011C on a 32-bit XP SP3. It also worked on a 64-bit Win7, but was crashing too often.are most running xp sp3 on a dedicated machine? i got vida 2013A with my dice unit.
Firmware is ok.so the fw is OK?
mrscullini
great, thanks! i figured a dedicated machine may always be needed.vtl wrote:Yeah, your host OS or hypervisor can't do a fully transparent USB bypass to a virtual machine.mrscullini wrote:is that my best hope?
just as an fyi, my host machine is a win7 home premium.
another question, memory and cpu requirements? i new at least a couple gigs on memory. any specific cpu specs?
vtl
If you laptop is able to run Win7, it's capable of running VIDA. Mine is 4 years old Lenovo IdeaPad y460p (SandyBridge i7-2630QM, 8GB RAM). But you need at least Win7 Professional (or fool VIDA's installer, google around).
Liliflower
- Year and Model: Volvo S60 2005
be careful about the ebay or aliexpress VIDA unit with only blue indicator flashes, the working DiCE unit is with colorful indicators (illuminates when good communication is built)
AS for the operating system, old VIDA (2012 A-D, 2013 A-D or before) should be installed on win xp or win 7 VMware, 2013A-D, 2014 A-D (current VIDA 2014D) can be loaded ok on Win 7 professional IE8, no win xp
2014A VIDA installation video:
2014D VIDA installation video:
For who meets VIDA NOT OK error, here is the document i googled, not sure if it works
http://blog.uobd2.net/uobd2-engineer-fi ... r-message/
Windows 7 ultimate, 2014D.
Interface test not ok. Exactly same problem like above.
My dice used to work well with VIDA & Vdash for many years. It stop work recently without reason. Both VIDA & Vdash cannot read my 2 Volvo.
I did uninstall& reinstall the dice and update the firmware again, 5.6.2, however, problem persist.
Please advise what I can do further.
lrock
- Year and Model: 2001 v70 xc
- Has thanked: 9 times
- Been thanked: 37 times
if you have $5 to spare, try using one of the w10 VMs at volvodiag.com using either vmware or virtual box.keng wrote: 27 Dec 2025, 18:04 Windows 7 ultimate, 2014D.
just remember to forward the dice units usb port to the vm.
- 16176 Views
Last post by xiaofei204716
- 10 Replies
- 18981 Views
Last post by jonesg
- 7072 Views
Last post by Klem
- 865 Views
Last post by xanthefin
- 11 Replies
- 16875 Views
Last post by cn90
