1996 850 Brake Bleed Nipple/Rubber Line Questions
Thanks guys. I'll just replace the bleed caps for now and keep an eye on the lines for bulging/leaking and replace them down the road. How much of a difference do the braided stainless steel vs rubber lines make on these cars?
- Has thanked: 311 times
- Been thanked: 817 times
I've never used the braided lines but people do say they firm up the pedal a little.TBrown00 wrote:Thanks guys. I'll just replace the bleed caps for now and keep an eye on the lines for bulging/leaking and replace them down the road. How much of a difference do the braided stainless steel vs rubber lines make on these cars?
Just wanted to clean up some contradictory or uncertain points in this thread, here is a summary for future readers:
(1) Volvo's OEM front brake hose is made by ATE: (2) In the DIY posted a few years ago, cn90 recommended ATE hoses (unknown what he actually used but it really doesn't matter, just trying to explain why people may be confused) https://www.matthewsvolvosite.com/forums ... hp?t=37721.
(3) ATE/Continental (http://www.ate-brakes.com/www/ate_de_en/) and FTE (http://www.fte-automotive.com/) are different companies.
(4) FTE brake hoses are also high quality, you can get front ones for about $18 each http://www.eeuroparts.com/Parts/43774/B ... ont-37050/.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Also in the spirit of helping future readers, I wanted to recommend checking out this thread on brake line replacement, which shows how to avoid or reduce the risk of stripping the fittings when replacing the lines:
https://www.matthewsvolvosite.com/forums ... le=desktop
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Pelican parts has the ATE hose for $10.25
The good thing about knowing the hose is OE is because they have access to all the data Volvo gives them about vibration, stretch on hose, peak pressure: in this case they would know best as they make the master cylinder.
Not that FTE may make a very good hose, maybe even better than ATE, as the ATE hoses all gradually develop cracks in the sheathing but they don't seem to fail and it would be tough to truly know which is better
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- 26 Replies
- 12888 Views
Last post by cn90
- 698 Views
- 42 Replies
- 5670 Views
Last post by erikv11
- 752 Views
Last post by sherry007
- 10 Replies
- 16463 Views
Last post by precopster
