New Heater Core - Should it look like this?
TBrown00
Year and Model: 1996 854 GLT
Post by TBrown00 »
Just received a new heater core from IPD and some of the fins are bent. Is this normal or should I sent it back for another one?
dosbricks
Been thanked: 4 times
Post by dosbricks »
My second ebay core had some bent fins--first one was perfect. I didn't sent it back--decided it was not worth the hassle.
Has thanked: 2205 times
Been thanked: 1852 times
These fins are mainly cosmetic and not in view once installed. Chances are more will get bent on installation. As they are pictured they will work fine. The fins are easily damaged by handling so be careful! I once had a radiator shipped with UPS that arrived bent in the middle but it was beyond repair and use. Dealer supplied another on an over-night.
Worth mentioning it to IPD though, as it could have been poor packaging that caused it and they may give you a discount.
TBrown00
Post by TBrown00 »
Thanks! I'll be extra careful installing it
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I had a similar experience with a Behr core I bought from IPD. It arrived with lots of bent fins. I sent it back and they gave me a refund (In my experience IPD has the best customer service in the car parts industry). I bought another Behr core from FCP, which arrived without as many bent fins -- it looked like your photos above. I installed it earlier this month and it seems to be working so far... I haven't noticed any problems yet.
hanzbe420
Year and Model: 2006 s60 2.5T
Post by hanzbe420 »
buy a fin comb there cheap..
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
Do not bother with a replacement: the fins are cosmetic. Furthermore, during installation of the core into the housing box under the dash: you will likely scratch the fins much more. (so even if you got a new one, you will most likely scratch it much worse than what you are looking at now)
The copper/metal piping of the core (what you dont see, underneath the fins) is what does the job of flowing coolant through it: the fins are just act as a heat sink. dont get caught up on details and extra time with a replacement... and get the heat running =) It is winter after all
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
dorvin
Year and Model: 1997 Volvo 850 T-5
Post by dorvin »
I had the same problem with a heater core I installed last weekend. A few bent fins, I combed them out, and about 400 miles later, so far so good!
TBrown00
Post by TBrown00 »
Installed it without any issues and it works great so far! Heat works and, most importantly, no more leaks
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
The fins are there, as on any radiator, to increase the surface area that's dissipating heat from the pipes to the air. I wouldn't call them "cosmetic", but if a few of them are flattened it just means there's not gonna be any airflow behind those. The effect on heat transfer will be negligible unless there's a giant patch of flattened fins blocking flow completely.
As other have noted, it's pretty tough to install the core without nicking a few fins anyway.
