1995 Volvo 850 when to change pcv system
Year and Model: 1995 850
Post by 2012 »
Hi guys,
Got a Volvo 850 of the 1995 turbo variety and I'm aware that when you have smoke shooting out the dipstick it's time to change the pcv system. But what about just little wisps easing out? And I did the rubber glove over the oil filler method and it does inflate but very slowly takes about a minute to fill it. Question is: can I wait until a leak develops to change it or would it be too late at that point and I should wait until aforementioned symptoms worsen and at what point should I tackle this job?
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Change it, change it now.
Replacing crank/cam seals will not be cheaper.
85 GLH, 367 whp
00 Insight, 72 mpg
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
You should have a vacuum on the glove so: x2 change it and change it now
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Now would not be too soon. . . .
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Been thanked: 4065 times
2012 wrote:Hi guys,
If a cam seal goes it is a 30 USD part and an hour of labor - not too bad.
If the rear main seal (RMS) goes, the engine comes out...1000 USD or more.
As Dirty Harry says..."Are you feeling lucky?"
Has thanked: 311 times
Been thanked: 817 times
Now would be a good time.
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
2012, there is a very active group of volvo enthusiasts in SD. They meet quite regularly and are a great resource if you are approaching a big job like the PCV with minimal experience. They also trade parts, offer advise, and get together for BBQs every month.
I dont know how I can get you in contact with them though. Maybe PM me?
Until you do the pcv, I would recommend pulling the dipstick up a little bit (not seating it all the way). (easy method). Anything that relieves pressure (in a completely clogged system) would be good. With the aforementioned method, you would have fumes going into your cabin; (easy but safer method) you can get some heater hose (2 or 3 feet), take dipstick out, and clamp the hose over the dipstick holder. and route the hose underneath the car.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
