1999 V70 XC New Pads & Rotors grinding when turning
PapaHepcat
Year and Model: v70 1999 XC
Post by PapaHepcat »
I haven't had my Volvo all that long. But a recent look at the rotors showed huge grooves in all four of them. So I replaced them this weekend. New pads and new rotors.
Now though, both of the fronts grinds really badly when I turn the wheels too far either to the left or right. If I'm just barely moving, it actually stops the car. Or if I ease up on the turn a bit, it'll grind and I can feel it catch and let go, then catch again, etc. I test drove around the block and it seemed to stop just fine when going straight. I didn't have the courage to try anything above 20 mph, if that.
Not sure if this matters: but I also did the front struts, as well as the inner and outer tie rods on both sides.
What have I done wrong?
Current car:
1999 v70 xc Silver, 170k miles
Non Volvo cars:
1991 Ford F-350, 80k(180k?) miles
2004 Toyota Sienna, 124k miles
Has thanked: 1609 times
Been thanked: 4064 times
Where the calipers and pistons moving freely when you replaced the pads? Once they start sticking the wear the brakes out really fast, then they will bind up on turns, too.
PapaHepcat
I could move them, but they were pretty stiff. Do they need replacing? Or can I clean them or something?
Current car:
Non Volvo cars:
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
PapaHepcat wrote:What have I done wrong?
what pads did you bought? some hard ceramics might be noisy (even on new luxury sport vehicles)
I would go with regular aftermarket pads, if I remember well Mintex make good pads with low dust
And of course, make sure the caliper slides really easily. Remove the metal sliding pin, clean it, then put only silicone grease inside the rubber boot. The piston inside the caliper might also be stuck but to check it you need to release the caliper bleeder.
PapaHepcat
Hmm. Maybe it's the calipers then. They were pretty stiff. I think the replacement pads were ceramic, but they were quiet when I applied the brakes from just moving forward. And the car stopped fine. Much better than before, actually. The grinding only happens when I'm turning.
Current car:
Non Volvo cars:
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
With wheels off ground, do they spin freely? Or do they catch while rotating and slow down at a certain point?
This would mean the rotor is not centered on hub (or has a hop in it while rotating, kindof like a wheel out of balance). There is a pin that holds the rotor onto the hub.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
IG-88A
Year and Model: '94 854T-'95 855GLT
Post by IG-88A »
This may sound silly, but check to make sure that when you installed the tie rod ends, that you didn't get in a hurry and flip one or both of them, or install them on opposite sides. They are curved for a reason and will only clear the wheel through a full turn if the arch in the tie rod end faces the right way. I foolishly got in a rush once because it started raining on me and made this very mistake. I didn't even make it out of the driveway before I knew something was seriously amiss. The sound and feeling was that scary.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Upon visual inspection, you should notice where the binding is taking place (drag areas on the disc surfaces - one side or both sides).
If binding occurs only in turns, I would suspect axial play in the hub.
In addition, I would remove the rotor, check for burrs on both mating surfaces (rotor and hub flange) and clean nicely before re-installing. The pin that holds the rotor on the hub is only a centering pin, make sure you do not overtighten it.
Before removing the caliper from the knuckle, I usually compress/expand it a few times to check if the pistons are moving freely.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
mika
Post by mika »
I recently read that our hubs are eccentric: inorder to properly balance the rotor on the hub it is recommended to tighten the rotor down with the lugs first, and then place the pin into the rotor and tighten it down. This promotes placing the rotor on concentrically. Then undo lungs, place wheel back on, ect.
'97 855 N/A
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
You could have bent the dust shields ever so slightly when replacing the pads/rotors. If so, they will bind and grind on turning.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
