98 S70 Hood Hinge Spring
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Hire OJ's.
- Year and Model: Many Volvos
- Been thanked: 76 times
I too am looking for an answer. My S70 apparently was wrecked at one time and both of the hood hinges are bent. I picked up a pair at a U-Pull lot but the only way I could get them off was to remove the fenders (one was already off) and then loosen the hinge mounting bolts to get everything to come loose. The springs were under tension and a lot of it, I pulled the bolts and let them fly.
After seeing how they came off they are still on the floor in the garage because I too am looking for a clever way to install them. The old hinges work but they let the hood go all the way vertical but that is a minor inconvenience compared to getting stuck and not being able to re-install the springs.
I'm guessing there is a small spring compressor that you could flip the jaws over on and use it as a spring expander but I don't have one. The strut spring compressors that you can rent are too big to fit the spring.
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
I used a very large pair of channel locks. It took a few tries.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
combatkarl
- Year and Model: 1997 850 GLT
I'm assuming you need to pull or extend the spring to remove it. If so, a tool similar to a 2 stroke exhaust spring hook might work. https://www.amazon.com/Motorcycle-Motorb ... B009YFEL0M
A larger version would be a Hay Hook -- http://www.tractorsupply.com/en/store/c ... B-hay-hook.
Similar tools are used for trampoline springs.
Karl
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
1984 Honda Nighthawk S bike
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
- 1169 Views
Last post by volvolugnut
- 32 Replies
- 5688 Views
Last post by MrAl
- 449 Views
Last post by MoVolvos
- 2565 Views
Last post by Turbo_Boss
- 9 Replies
- 3885 Views
Last post by 98v70dad
