1994 Volvo 850 - N/A to Turbo conversion
mmd94
Year and Model: 1994 Volvo 850 Base
Post by mmd94 »
Thanks Ozark Lee! Helps a lot.
mmd94
Post by mmd94 »
Hey Ozark Lee, Do these spots look about right?
Oil feed line location (not yet drilled)
The oil return on this block im not sure if its correct or not, but I believe it will be this spot (circled)
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I have no idea. On the turbo block the socket is cast into the mid block section. The pictures I posted were actually from a '99 LPT engine and the supply may have changed since the internal oil passages were rearranged to accommodate the CVVT and the changes in the oil cooler system. The oil cooler system change wasn't much since it was all in the sump pan.
cleven
Year and Model: 2001 V70 T5
Been thanked: 5 times
Post by cleven »
Iv been doing lots of research on this matter my self. I cant find no T5 wagons so im just gonna have to get an N/A and just swap out.
Has thanked: 1609 times
Been thanked: 4065 times
cleven wrote: 26 Jun 2021, 17:42 Iv been doing lots of research on this matter my self. I cant find no T5 wagons so im just gonna have to get an N/A and just swap out.
Are you going turbo to NA? That’s easier to get something driveable although it will drive sedately.
I’ve got a T5 block out in NY if it helps anything.
