1996 850 - OBDII scanner showing front O2 sensor only?
Volvo Tank
Year and Model: 1996 Volvo 850
Post by Volvo Tank »
I hooked up my scanner, and for some reason it is pulling live data but only registering the front oxygen sensor only....
Here is the output:
FUELSYS1 CL_Fault
O2S B1S1--- B2S----
O2B1S1(V) 0.740 ?
SHRTFTB1S1(%) 1.6
Any ideas? Is the CL_Fault due to the other O2 sensor not being found? Wouldn't that throw a code?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
There are some scanners that can't seem to get to the rear sensor. Is your check engine light on?
Volvo Tank
CEL is not on...if that's the case then I guess it's probably safe to assume it can't read it?
That sucks...I have a sneaking suspicion it needs to be replaced, but it sounds like there isn't a real easy way to do that now
Post by Ozark Lee »
If the ECU couldn't see it then there would be a CEL for sure so I think we can assume it is functioning. The rear sensor really doesn't do anything in terms of performance. The rear sensor's function in life is to monitor the efficiency of the catalytic converter but all of the mixture calculations are based on the front sensor reading.
Volvo Tank
Got it...thank you for the help!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
Often the front O2 sensor will be dying for months before setting a code. Fuel economy drops.
Also -> Amazon link
Volvo Tank
That is good to know, since that is exactly what happened. Figured it may be the rear since it wasn't registering
