My wife smashed the passenger side outside mirror backing out of the garage. My local garage says they would have to order all the pieces and assemble it all together which would cost an arm and a leg. Is it possible to buy a complete housing and put it on myself? Is that a difficult operation? I am not that familiar with car repair, but if it's not too technical, I think I can figure it out.
Any thoughts are appreciated.
Thanks!
Edit: I've found what I think is the right assembly: http://www.ebay.com/itm/04-07-VOLVO-S60 ... 1586609681
Does that look right? Is it a matter of popping the cover on the inside, removing the bolts and replacing the whole thing?
2007 S60 Need to replace passenger side mirror
Hi there, not sure if you are still looking for a mirror and help on this but replying anyways
I believe that mirror you had found is a little different then what you have, yours should have a turn signal on the housing of the mirror check your good one, if it doesn't have it then yes that is correct type of a mirror, as far as replacing it you will need to pull the door panel off in order to get access to the electrical wire then there is only one bolt either 12mm or 13mm behind the black triangle cover and that's all
hope this helps
also if you are still looking for one let me know i might have something
hope this helps
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
- 554 Views
Last post by URDRWHO
- 824 Views
- 1625 Views
Last post by Jkappeyne
- 1243 Views
Last post by oragex
- 1679 Views
Last post by 850_GLT_Owner
