vibration at speed
jimbo.k
Year and Model:
vibration at speed
Post by jimbo.k »
hi guys, still need ya help.
got a vibration thru the whole car around 90-105 then it dissappears, had the front wheels balanced but still got the vibration. any ideas/
jimbo.k :roll:
Peace_Frog
Year and Model:
Post by Peace_Frog »
Hi there, Jimbo.k,
I wish I knew the cause of your problem, I have the exact same behaviour on my '97 855 turbo AWD, except the speed at wich it happens is exactly 102 to 110 km/h.
I thought my back tyres were in cause, because they needed to be changed, but after replacement by new ones: same vibration at same speed!
I just started to look into the problem again and found this post:
https://www.matthewsvolvosite.com/chat/p ... =vibration
I'll investiguate some more and will get back to you (and the group) if I find something.
Did you solve the problem yet?
Thanks,
Hugo.
Peace_Frog
Year and Model:
I also found this thread:
hinting at a driveshaft problem. Say it ain't so, Jimbo :cry:
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
Peace Frog: you might want to have new tires/tyres ;-) put on the front as well -- same brand, same model, same size of course. Reasons:
it will either fix your vibration problem, or it will rule out tires as the culprit
and
it will save your AWD planetary gear(s) from unecessary wear that leads to gear failure
If one of the four tires is a little bit bigger or smaller than the rest due to different brand or differnt tread height, the gear turns the sides at different speeds, constantly. This was a weak spot in Volvo's AWD system, one that they fixed in recent models.
Also -> Amazon link
Peace_Frog
Year and Model:
Good call Matt.
I have to buy a new set of winter tires for our crazy Quebec winters, but meanwhile... do you thik I can create a lot of trouble$$$ by waiting untill then? Our winters are severe but I was hoping to wait untill november for those new tires!
Thanks a lot, for this response, and for this great Web site.
Hugo.
matthew1
Site Admin
Post by matthew1 »
Hugo,
It's so hard to say. For the most part I read about these things and (along with some common-sense mental checks) regurgitate it here. I don't have an AWD nor have I ever worked on one. I've just worked on my 850 and read a few million 850 posts online ;-).
I would call a Volvo dealer and ask to speak to a mechanic, or stop by and speak to one. Or the parts guy -- he's usually pretty good. Ask them about the tire situation.
Also -> Amazon link
