I have exactly that unit. I also have its partner unit that is a direct OBD II connection.pappatho wrote:Has anyone successfully used a Wifi ELM327 device? I have this one http://www.obdinnovations.com/elm327-wi ... e-android/ and so far haven't been ale to get it to work. I have tried changing the scanner type to OBDlink in the .html for volvo850 diag, but I still can't get anything to happen when I hit the Start Realterm button. My PC shows I am connected to the ELM327 but I am not getting any flashing lights on the ELM327 like I do when it is connected to my Ipod. It does show that bytes have been sent and received.
My main goal right now is to be able to pull the mileage on my '97 855R.
They will never retrieve original miles.
Try one of these, for what it is worth.
https://www.matthewsvolvosite.com/forums ... 37&t=60660
The original schematic, not my Foo-Foo.
Either way, look up the codes, and pin positions to find mileage as you would from an OBD I port.
I have not even checked the mileage on my '96, But have used it to find fault, and erase codes in My ECC, as well as reset CEL and SEL.
Using the under hood OBD I in my '93, I was able to do all the above.
Lucky to find the odometer had broken only 20,000 miles from the reading.
Enjoy.
