Things you NEVER want to do to your car or truck …:
94 Volvo 850 TM, Car turns over but no start.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
huzzsaba
- Year and Model: 2004 volvo xc90 2.5t
So did a little checking today and it seems like fuel is coming. I can smell it and after cranking it for a while, there was a good amount of fuel that came out of the schraeder valve. If it turns out there is no spark, what would be the first thing to check? distributor? cam sensor?
Sorry it is just so cold here that its hard to check multiple things together without freezing.
2004 Volvo xc90 2.5t
1998 Volvo s70 T5M
1998 Volvo s70 T5M
huzzsaba
UPDATE: nothing positive though. I got around to listening for the fuel pump and after dropping the back seats and listening, you can clearly hear the pump priming. When I crank the engine, I can smell fuel so I think fuel is no the issue.
I replaced the coolant temp sensor, but still no start.
I finally got around to checking for spark, and there is none! what would be the next step? Distributor? Cam sensor? Crank Sensor?
Please help!
Please help!
1998 Volvo s70 T5M
1998 Volvo s70 T5M
- Has thanked: 1611 times
- Been thanked: 4075 times
Pull off the cap rotor and post pictures.
When were they last replaced?
huzzsaba
I will check first for check spark from the ignition coil. I was told by a former Volvo tech to remove to remove the wire going from the coil to the distributor cap and check for spark. How do I check for spark with just the wire without the use of a special device? Just place it on a metal part of the engine like I would with a spark plug?
1998 Volvo s70 T5M
1998 Volvo s70 T5M
- Year and Model: Lots
- Been thanked: 128 times
Yes it's the same spark that gets to the plugs but is a little stronger because it's bypassing the rotor button's internal resistor and firing all of the time.
huzzsaba
Just to be clear, I understand replacing parts is the way to go, but with money being tight right now, I would rather clean up the parts to get the car back on the road until it gets warm out when a full tune up will be done. I am all for replacing parts but just can't right now so please suggest if there is hope in cleaning parts.
Here is my plan of action:
1)Check distributor cap and rotor for cracks and if cracked replace, otherwise clean the contacts.
2)Check for spark at ignition coil and if no spark, I don't think cleaning is an option so I will replace.
3)check and clean cam sensor (please suggest method of cleaning)
4)check and clean crank sensor. (please suggest method of cleaning)
1998 Volvo s70 T5M
1998 Volvo s70 T5M
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
When you get to the cam sensor, the harness connectors become very brittle in my experience, leave it plugged in when you check/clean it, otherwise you may have a handful of crumbs. Also, if no spark from coil, check power IN TO coil before just replacing, unless you have a spare.
Current Volvos:
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Good plan. On the dist cap, look for carbon tracks around the posts, if there are any need to replace. If not clean best you can around posts and center contact, make sure the center piece that contacts rotor is there. Do not attempt to clean the posts w/sand paper or file as you may scratch cap. Use fine file to lightly reshape rotor tongue as it needs sharp edge to initiate spark. Bottom line is, if you get spark with plug on the block, distributor is fine. Regap plugs to spec as well. If spark okay and still no start make sure timing's good. Make sure crank sensor connector is clean and tight, connector pins not pushed in.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
draser
Forgot to mention, since you have separate coil, before replacing you can test it. Just unhook existing wiring (separate from car electrical harness), connect a short wire to one of the posts to battery positive and use another short wire from second post to touch ground. Connect a plug wire to high voltage post of coil and with a plug laying on block you should see spark when touching chassis ground with you primary wire.
- 700 Views
- 15545 Views
Last post by BlackBart
- 392 Views
Last post by RaisedYaw
- 1016 Views
Last post by draser
- 1010 Views
Last post by lewiskoolman72
