93Regina wrote:Answer: ECU Fuel Pump Control Circuit Repairbobbycgolf wrote:Why will the key not turn on the pump?
90 240 DL wagon only starts with starting fluid when cold.
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
Did you read the section titled:lummert wrote:93Regina wrote:Answer: ECU Fuel Pump Control Circuit Repairbobbycgolf wrote:Why will the key not turn on the pump?
561 ECU Workaround: Swap the Relay and Not the ECU
This may be a solution to your problem.
1988 Volvo 760 Turbo Wagon
bobbycgolf
- Year and Model: 1990 240 DL wagon
I did... Read it about 10 times. Trying to kick it around in my head,am more of a visual type I guess. I did wire in a momentary 20A push button and ran wires up thru the mid console and put it between the cig lighter and rear window defrost. Looks as if it belongs,and from now until who knows when it will belong. Push of the button and thrn of the key and its all fixed ish.
bobbycgolf
Want to thank all who replied. Thanks for your patients and lending me an ear to bend. Next on the list is ball joints and a bath.
bobbycgolf
Also was still wondering if anyone else has the noisy as hell FP relay?? New one and old like a rattler?
bobbycgolf
Oh.. Now your earlier post makes alot of sense to me. Thanks a bunch. Will fiddle with it tomorrow.
- 1756 Views
Last post by doublebug
- 147 Views
Last post by cn90
- 3111 Views
Last post by nucci480
- 4682 Views
Last post by Roger M
- 1537 Views
Last post by volvolugnut
