Hey
my 2000 xc70 70 is giving me p0013 and p0237. About 3 months ago I put in a new ipd heavy duty control valve & everything has been working fine, but the other day, it would start but I couldn't move (stomping on gas moves needle to 1500 rpm). Also my charged air pipe was collapsed like it was sucking too much air (see picture). Do I have a bad tcv, or is this a map sensor problem, or is this related to the cvvt solonoid that I replaced a month ago (I am assuming that's where my p0013 comes from)?
Does this tube get sucked in because of p0237?
MilwaukeeV70owner
- Year and Model: V70 XC SE, 2004
- Has thanked: 1502 times
- Been thanked: 3817 times
It's that time of year!!!!
MilwaukeeV70owner
So do I just need a heat gun to be up and running again?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Heat gun is probably to aggressive. Just a passive heat source will be good. The intercooler is between the radiator and AC condenser. Once warmed up, make sure the small hole in the bottom of it is clear.
