So I found a 1998 V70 online. The guy said there's a new thermostat, new head gasket, new heater core, new battery, new tires, new brakes. He had the heads resurfaced and a compression test showed no leaks, had it scanned and no codes showed up.
That's all fine, but he said it needed coils and spark plugs because it vibrates a lot but that it goes away once you're driving it. The ignition coil needed replaced because his father spilled oil on it. I don't know why the spark plugs need replaced.
My question is actually a bit of confusion and some need of clarification.
If the ignition coil was damaged and needed replaced wouldn't that mean the car wouldn't start?
If the plugs are bad and causing vibration wouldn't that continue while you're driving?
And finally, if you're going to go through all the trouble to fix the other things, why wouldn't you fix the last two issues?
What other causes could make the car have those symptoms?
98 V70 Thinking about buying this car and have questions
danilouise
- Year and Model: V70 GLT Turbo 1998
Topics merged.
Plugs and coil can fail under load yet start and idle fine. Inspect the distributor cap and rotor though.
If rest of car checks out, have a mechanic run a compression test to check the top end of the engine.
Replace plugs and coil while doing the test. If that fixes it, congratulations!!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Sometimes it takes a few miles for the codes to surface. Did you scan it or search just look for a CEL?
- dosbricks
- Been thanked: 4 times
It would appear that you have posed the key question. Buyer beware.danilouise wrote:
- rspi
Contact rspi..
If the price is RIGHT and you have the ABILITY to fix it, proceed. If you don't do these type of DIY repairs, simply run. We all can use more exercise.
Pick up an ignition coil and some plugs from the pick a part (most cars will have bosch for both).
Swap into car without buying it (10 minutes) see if it helps! You can always subtract cost of parts (even if new) from asking price
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
New thermostat, head gasket and heads resurfaced all point towards catastrophic failure of the HG leading to severe overheating. An event like this would lead me to question the maintenance regime of the current owner ... well that coupled with the fact that they can't be bothered to change the spark plugs.
+1 on Robert's tip
+1 on Robert's tip
but if you're not sure of your abilities or doubt that you have the time or patience to put someone else's mess back together - run for the hillsrspi wrote:If the price is RIGHT and you have the ABILITY to fix it, proceed.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
jose456891
- Year and Model: 850 GLT 2.4 1996
rspi wrote:We all can use more exercise.
lol
OP: Mate, go for it, go in and be prepared. Buy a compression gage and use it. If the compression is OK, and the gearbox shifts fine, buy it.
We'll help you figure the other issues. Hell I'll personally help you, I'll even help you wrenching.
But yeah, what RASPI said...
danilouise
Thank every one of you for responding to my post.
Two days after I wrote this, he posted the same car on the same site at about 9:30 PM, but instead of asking 1000 US he dropped it to $500. I messaged him saying I would come see it the next day, cash in hand and that was fine with him. An hour later he said he sold it.
Perhaps I dodged a bullet or didn't live close enough to pick it up right away. Either way I feel like I could have fixed some things especially with the money saved.
Oh well ... c'est la vie!
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
I've sold cars that needed minor work, and even thrown the parts in the trunk with 'em. Selling a car that needs work can be a fatigue thing - it's not the the road ahead is impassable, but I'm just too tired to keep walking.dosbricks wrote:It would appear that you have posed the key question. Buyer beware.danilouise wrote:
- 1427 Views
Last post by paredown
- 1845 Views
Last post by precopster
- 1120 Views
Last post by matthew1
- 9 Replies
- 2158 Views
Last post by tryingbe
- 13 Replies
- 2861 Views
Last post by F250
