2000 S70GLTSE Blown Head Gasket. Fix or Parts Car.
2000s70tampa
Year and Model: S70GLTXE 2000
Post by 2000s70tampa »
Title sums it up. 105,000 miles. Had the radiator replaced 6 months prior (sensed it wasn't done correctly) and sure enough blew the head gasket - don't know if cylinder head is cracked.
The car is in "good" condition - no wrecks, cosmetic wear & tear, new tires, GLT SE package, fairly well maintained,
Been sitting for 2 years and need to sell, fix (at least $ 1500) or sell for parts thru there. I would appreciate any recommendations. 813 227 8575 if you have any interest in her. Tampa, Florida.
volvooh
Year and Model: '98 S70, '05&'08 V70
Been thanked: 4 times
Post by volvooh »
I have seen some get more life out of their vehicle with something like barrs or k seal. Its not a permanent fix, but I have seen it last a year if not more till it makes $$ sense to replace the gasket.
That said, I am sure you are in the $1500 range to repair an HG on a car that would likely retail for $2500ish. If you are not going to keep it, parts may be your best option...someone may take a chance for $500 or so, but that I cannot see someone buying it for more than that.
If it were me, I'd probably bite the bullet and do the head gasket. It sounds like otherwise its in good condition and I would be hard pressed to find reliable transportation for less than $2500.
