dash lights go out when other circuits used
weird beard
- Year and Model: 850 glt, 1996
1996 Volvo 850 wagon, 2.3 turbo. Just started doing this. I rolled the windows up and all the dash lights went out. they come back on when I stop using the windows. Adjusted the fan speed on the HVAC panel and they went out again. Cycled the key, they came back on until I loaded the window or fan circuit. I don't know what else is being affected by this yet. Car still runs, headlights still work. Display on radio still working, all back lighting flickering or going off completely. I don't believe the fan works when the lights go out. Sometimes they flicker, sometimes they dim, sometimes they go out completely. Like I said, it just started doing this, as I pulled up to the house and rolled up the windows.
- Has thanked: 1613 times
- Been thanked: 4075 times
Loose connector or perhaps bad grounds?
Are you an electrical novice, guru, or zen-master?
weird beard
I'm pretty good with the electrics. Spent years as the electrical "go to guy" at a Volvo TRUCKS dealer. However, I had full factory wiring diagrams, diagnostic tools and years of having seen similar issues on similar models. I will likely find it, thought I would post it up here to try and save myself some time. For alli know, this is a known issue with a known cause
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Bypass the dash dimmer and see what you get.weird beard wrote:I'm pretty good with the electrics. Spent years as the electrical "go to guy" at a Volvo TRUCKS dealer. However, I had full factory wiring diagrams, diagnostic tools and years of having seen similar issues on similar models. I will likely find it, thought I would post it up here to try and save myself some time. For alli know, this is a known issue with a known cause
We have an agreement with Volvo that we don't host electrical diagrams here but we can point tomthem for you. The headlight switched on these cars have a recall for some years and are a good starting point.
- 16 Replies
- 3431 Views
Last post by smacknab
- 353 Views
Last post by mitchmoney6
- 13 Replies
- 2411 Views
Last post by E Showell
- 485 Views
- 1183 Views
Last post by ZionXIX
