Wheel Hub Swap on 850, s70 or v70
tzanis
Year and Model: 1997 850 GLT
Post by tzanis »
I was wondering, how easy or possible of a job would a wheel hub swap be on an 850, s70 or v70.
I know one would also need rotors for the swap, but I was thinking that there is a wider range of rim choice when for example going from 5x108 to 5x114.3.
If anybody has done this, or has any more thoughts about what is needed to be done please post it here.
If my starting this thread is not appropriate or relative, please admins, take it down, no problem :)
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
You can't just install a wheel hub from other car/make...even if it's from a smaller s,v40 Volvos.
Wheel hubs with 5 bolts are interchangeable across all 850&s,v,c,xc70 models up to 2001.
Could be also with newer models from 2001 but i'm not sure on this.
www.wheelfitment.net will give you an idea about bolt patterns between brands of cars.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
tzanis
Post by tzanis »
Thanks for the info misha :)
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Here's a sample link to FAG's catalogue:
http://fagcatalog.schaeffler-aftermarke ... o6Ulc4MjMz
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Ben850
Been thanked: 7 times
Post by Ben850 »
I am currently using '04 S60 Wheels with snow tires on my '96 Wagon with no issues.
The AWD are different rotors and rear hubs.
The S/V 40 and 50 models may have a different offset. The 5- lug pattern, I believe is the same.
Picked these up for a good deal. 15" forgot the name, will edit.
The 16" Columbas, were put away, for the winter.
They look alright and help with the pothole issues here in Michigan.
I have another set of original '95 T-5R 17" Titans for the Wagon this spring.
Which combination were you looking at?
The hub swap I may do will be on my '93 from 4-lug to 5-lug.
I have a complete rear delta link setup from a '98 S70 and a couple front hub/bearing units.
Could have simply changed the rear hubs, but found a scrap '98. The bushings were all shot in the '93 rear, so this will work great in my situation.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Volvo have a very large FWD oem wheel selection.
I got S80 17 inch interceptor wheels on my 94 850.
http://forums.turbobricks.com/showthread.php?t=72501
85 GLH, 367 whp
00 Insight, 72 mpg
Ben850
Post by Ben850 »
tryingbe wrote:Volvo have a very large FWD oem wheel selection.
Those were another consideration that I had seen from an S80 on Craigslist.
tzanis
Post by tzanis »
My initial thought was if anybody has changed hubs that fit the volvos, but with a different pattern e.g. 5x114,3 or 5x120, because these kind of patterns have a way bigger market and a lot more rims are available. A lot of useful info though, and thanks . I love the 17 titans ben850. Thanks for the part regent
misha
Post by misha »
More things would be involved to match with "new" hubs.There are axles,cv joints,could be transmission too.All of those parts needs to be matched with "New" hub.
If you really want to go that route,there are wheel spacers on the market with desired bolt pattern but made to fit your original hubs.They can also be custom made.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1504 times
Been thanked: 3817 times
If anyone needs wheel hub covers for new wheels I have them for 16.80 each, or 4 for 79.00
