I just did a full top end rebuild on my 99 2.9l s80. Rebuilt head, water pumpp, timing belt, cleaned up the intake. ETM has issues so that is going to xemodex. Anyway prior to pulling the car into my garage and tearing everything down transmission was fine. The other day after I rebuilt everything I started it up to test it. Runs good, other then the ETM issues, but here is the kicker it will not engage into gear. No matter gear I select it acts like it is in neutral. I would say tranny went bad but given it was fine when I put it in the garage thinking not likeley. Is there some sensors or wiring I should check that I may have knocked off when I was doing all of the other work?
Jeff Banko
99 s80 tranny won't engage
- 1097 Views
Last post by oragex
- 660 Views
Last post by fireman0977
- 1781 Views
Last post by MyS40T4
- 826 Views
Last post by doublebug
- 1205 Views
Last post by misha
