1995 Volvo 850 turbo CV boots ripped.
Correct Axle for a 1995 850?
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
If the boots have been torn for sometime it is usually safer to replace the entire axle. These can be sourced from Raxles. The guy who runs it, Marty, is a great guy.
Removing axles/repairing boots:
http://volvospeed.com/volvo_repairs_how ... ement.html
Raxles
http://www.raxles.com/contact.aspx
Raxles
Ben850
- Been thanked: 7 times
Thanks for reminding me.
Let me know how it goes.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- Has thanked: 311 times
- Been thanked: 817 times
Make sure you get quality CV boots. GKN/Lobro, do not get EMPI or Rein boots.
http://www.autohausaz.com/pn/271648O
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You don't need to replace entire axles because of torn cv boots.Only things which needs to be replaced are cv joints.They come as a kit with cv joint,boot and clamps.Quality cv joints usually come allready pre-filled with grease.Use Gkn Lobro cv joints because they are oem parts.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Many Volvos
- Been thanked: 76 times
If they aren't clacking then you can usually just buy the boots and stuff them full of grease. The GKN/Lobro boots are readily available from NAPA or CarQuest.
Once they start making noise then I usually just replace the axle but I have made a number of missteps when going that route. The only axle I will buy now is from Marty at Raxles. All other aftermarket or auto parts stores rebuilts have been terrible.
Looks like this repair is next on the list. Passenger side outer boot is torn through on one of the inner creases, no grease getting flung out yet though. Driver side outer boot is solid but looking rough, lots of surface cracks.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Very surprised to see that AutohausAZ has those. Last year I ordered boots from them and all they had was Conti/Rein. I went ahead. The pass outer boot now has a tear in it. I called them to ask about a warranty, but they said no joy. The boot could have also torn due to hitting something, not sure. But good to see they now stock GKN and at a good price.erikv11 wrote:Make sure you get quality CV boots. GKN/Lobro, do not get EMPI or Rein boots.
To the OP: I did this job myself for the first time last year. I did the pass. side first. Very, very messy. Royal PITA getting the circlip to release so I could remove the joint, which was very, very tight. I wound up using a pneumatic hammer to both remove it and reinstall. Getting the correct pliers made all the difference in preventing the circlip from continuously slipping off. With that sorted, the driver side was MUCH easier. No worries pulling either axle out of the transmission, no sticking at all.
Good to know others here recommend Raxales.
M1 10W-30 HM
M1 10W-30 HM
- sleddriver
When I just checked NAPA's site, all the boots they listed were made by EMPI. Do you have a link or part number for GKN? Thanks.Ozark Lee wrote:If they aren't clacking then you can usually just buy the boots and stuff them full of grease. The GKN/Lobro boots are readily available from NAPA or CarQuest...Lee
M1 10W-30 HM
M1 10W-30 HM
- 1296 Views
Last post by pedal2metal
- 261 Views
Last post by jmartin919
- 1654 Views
Last post by erikv11
- 528 Views
Last post by mika
- 17 Replies
- 3726 Views
Last post by xHeart
