91 240 fault codes 2-2-3 and 1-1-3
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Re: 91 240 fault codes 2-2-3 and 1-1-3
Post by 93Regina »
91volvo240 wrote:solve everything
High impedance Volt-Ohm meter is what is used to evaluate...via checking voltage/ohm readings at various points.
91volvo240
Year and Model: 1990 240
Post by 91volvo240 »
I installed the new 02 sensor, but it didn't make any difference. The fault codes came back again.
I've checked the AMM and the IAC-- everything checks out fine.
As I was checking resistance on the control unit connector, I noticed that the readings were off on the TPS.
The service manual says to connect the ohm meter between ground an no.2-- the reading should be 0 (switch closed), then depress the gas pedal and resistance should increase to 2-3 kohm (throttle switch opens).
When I performed this test, I got 3 kohm without pressing the gas pedal. So, I adjusted the TPS until I got a reading of 0 with the throttle closed-- but the "click" I'm supposed to here from the TPS is gone when I do that-- so that means it's not adjusted properly right?
What am I doing wrong? It's a brand new TPS.
Getting close to pushing my beloved volvo off a cliff!
93Regina
Post by 93Regina »
91volvo240 wrote:Getting close to pushing my beloved volvo off a cliff!
God no, don't shoot her. Just kick her in the butt ever so often.
93Regina
Post by 93Regina »
91volvo240 wrote:When I performed this test
Do it, by the book: LH2.4 Manual Complete
Follow their instructions...
