93 940 Wagon Tail Light Issues
Dalpatine
Year and Model: 92 740 Turbo/ 93 940
Post by Dalpatine »
Hello,
I have been having issues with the driver side tail light assembly. I have replaced all bulbs, the bulb failure relay, and still I have no brake lights or running lights on the driver side. The car has 260,000 miles on it but is in solid shape with very little rust. I am thinking my next step would be to replace the entire assembly. Any help or ideas, especially a detailed wiring chart of the colored wires would be very helpful.
Thanks all!
Dalpatine
-1992 Volvo 740 Turbo Wagon
-1993 Volvo 940 Wagon
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Try this for wiring diagrams:
http://www.volvowiringdiagrams.com
2016-MAY-15 EDIT by matthew1: THAT SITE IS CURRENTLY TESTING POSITIVE FOR MALWARE. I SUGGEST YOU NOT VISIT IT. IF YOU MUST GO THERE, CHECK HERE FIRST FOR CURRENT INFECTION STATUS: https://sitecheck.sucuri.net/results/ww ... grams.com/
Reason: added malware notice
1988 Volvo 760 Turbo Wagon
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Dalpatine wrote:no brake lights or running lights on the driver side.
Use voltmeter to see if power is present...if so, find/clean ground.
Dalpatine
Post by Dalpatine »
Thanks for the ideas! I will give them a try and report back!
Dalpatine
Dalpatine
Post by Dalpatine »
All,
I installed a new tail light assembly and all the lights are working as they should, but I'm still getting a bulb failure light on the dash, this is after I also replaced the bulb failure relay.
Any ideas?
Dalpatine
93Regina
Post by 93Regina »
Dalpatine wrote:bulb failure light on the dash
That device is in effect measuring a difference in amp draw, aka wattage.
All replacement bulbs must be of OEM wattage specs....also, if oxidation/etc exists on a bulb, or its receptacle, less current draw will be "seen" via that device.
Might use electrical contact cleaner on the dirty bulbs, and their receptacles.
Dalpatine
Post by Dalpatine »
Alright,
I will try this and see what happens. Thanks!
Dalpatine
