98 xc70 Mud Flap under body
- Has thanked: 2200 times
Hi northern friend, hope this link works. You need items 17, 22, and 25, as long as the mounting points are part of the rear jacking point. If you don't have them, then you need the jacking point #16.
Sorry, that is weird as I did attach it! I'll do that again then!!
http://www.volvopartswebstore.com/showA ... egory=7873
Look at part #'s 16, 17, 22 and 25
Part #16 - Jacking pad 9474533 (may not be needed)
Part #17 - Mud flap 9474091
Part #22 - Retainer, black 3521768
Part #25 - Sems screw 977509 (Holds 16 in place so may not be needed).
Anything is possible, but on the AWD cars, they have an additional jacking point with a bracket that these mount to (Part#16). However, if you are creative, there is no reason I can see that you couldn't fab a simple mounting bracket with angle iron and bolt to underside of your car. You may find there are exiting hardware in the area that you could use to mount a bracket to.
Neil
Neil
- 1349 Views
- 728 Views
Last post by Andrew Vanis
- 3207 Views
Last post by MadeInJapan
- 1371 Views
Last post by rcannon
- 22 Replies
- 6032 Views
Last post by Cookeh
