Any Volvo Question about HF fuel press gauge
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
Has thanked: 2205 times
Been thanked: 1852 times
Assuming you mean the $20 version, provided it has a threaded end that can screw onto the Schraeder valve on the end of the injection rail it should be ok, and if it has a range covering 3-4 bar, or 40-65 psi you should be good. Any other opinions guys?
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
One must take the throttle body off before doing any fuel test.
85 GLH, 367 whp
00 Insight, 72 mpg
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
tryingbe wrote:One must take the throttle body off before doing any fuel test.
Why's that? I have a T5 with the TB under the manifold, and I seem be having fueling issues. If I have to drop the ETM to check fuel pressure, I'm going to push the car off a cliff.
JimBee
Post by JimBee »
I found this You Tube vid that shows how to use a standard pressure gauge and length of rubber fuel line. Also, answers the question about what to do with the schrader valve—remove it during testing. The demo doesn't mention if fuel gets into the pressure gauge. Guess I'll find out.
Seems pretty simple.
tryingbe
Post by tryingbe »
Why's that?
on 850, bracket is in the way.
85 GLH, 367 whp
00 Insight, 72 mpg
j-dawg
Post by j-dawg »
Phew.
I rented a kit from Autozone, and it costs a $160 deposit. I'll get it all back when I return it, and I wanted it this weekend, but I feel like I'd rather pay $20 and get a crappy HF tool that I can keep, even though I'll only use it on occasion.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
The O'rielly kit did not work on 2001 V70XC.
There was not enough room to connect on '97 850 -- the bracket is in the way.
I would like to know how your's go?
Will you test the fuel pressure regulator?
j-dawg
Post by j-dawg »
I'll post results when I get 'em, probably this weekend.
The car's been behaving strangely lately, and I'm no longer so sure it's fueling-related. We'll see.
JimBee
Post by JimBee »
No comments on the hack in the You Tube video? That might be the cheapest option and most adaptable since you can bend the hose around obstacles.
