2007 V70R Rear Door wiring Failures, wont unlock
severe wire failures, rear door wont open and wipe stops. Check wire harness at hinge area. I found 8 broken wires and 3 exposed but not completely broken. Door is hard to open when it will not unlock.
jimmy57
- Been thanked: 320 times
It's a flaw all makes have in their wagons. I have repaired or replaced wires in Explorers, Expeditions, VW, BMW, Mercedes, etc, etc
i have repaired the original wire where test lead wire (more but much smaller strands inside the insulation) was used and even that fatigued and broke.
The mini-van way with spring loaded contacts and contact pads is a great way to do it but it wouldn't support power tailgates and other items in tailgates that work with it open.
