'98 V70 -- Slight hitch in driver's interior door pull
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I noticed a slight hitch developing in the driver's side interior door pull on the '98 V70. Feels like the chrome door pull is fetching up on the plastic surround. Anybody experience this before? Is this a sign of impending death of the door pull or something else?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 2200 times
Been thanked: 1852 times
Hi Evan,
If I understand what you are saying, the 'chrome' part of the handle is rubbing on the surrounding plastic it sits in?
It is a pain, but removing the door panel will be the easiest way to figure out what is going on. It could be as easy as just needing lubed. There is a plastic clip that holds the cable from the handle to the lock mechanism that may have jumped out or broken, or even just try re-positioning the door card might be all that is going on.
Be very careful prising the plastic surround off around the interior pull handle as it has long clip legs on it that like to snap. You will also probably break a few of the door card plastic clips as they go brittle. I collect these from PnP when I see any panels and try to keep a few on hand.
E Showell
Post by E Showell »
It was, indeed as I suspected -- the impending death of the door pull. Today while running errands, I pulled on the chrome interior door pull and it did not move. It is obviously broken. Fortunately, I can still lower the window and use the exterior door handle to open the door. It appears as though the interior door pull will need to be replaced. Anybody done that before? (I now have a matching set of front door problems as the passenger door only opens from the inside.)
'95 855 auto (sold)
obayha
Year and Model: V70 1999 Base
Post by obayha »
Sounds like you might need some parts. Not new, by any means, but let me know if I can help.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
E Showell
Post by E Showell »
Shane -- I may hit you up, but I have to get the door panel off to see what's going on. In the meantime, check your PMs, as I did have another parts request.
'95 855 auto (sold)
