Can anyone out there tell help me with putting the shaft of Rack and pinion back into the steering wheel coupling? This is the place that I am stuck at the moment!
Thanks!
cturner38
98 vovo s70 Rack and pinion replacement
I got the shaft in but now having an issue with the bolt/screw of the large fluid line. I posted some pics on the s80 forum because they had the rack issue! This is all I needed to do to complete the job but the bolt/screw isn't catching!
Any suggestions! I hate to take all of this apart again!
- chrafael
- Year and Model: 1998 v70 GLT
- Been thanked: 10 times
Are you sure that o-ring is in the right place? The line doesn't look straight enough, It has to be perfect. You may need to loosen the rack bolts some or tweak the line a little. A 3/8" drive 12 point 19mm flare socket would help to tighten it. I got one on ebay for about $20.00.
- Has thanked: 1611 times
- Been thanked: 4075 times
Loosening the two pieces on a union joint is a intermediate mechanic trick. The best application is on brake calipers where it is a lot easier to start the brake unions with the caliper off the car, the mount.
Loosen the rack until you can move it by half the union diameter. If the rack calls for torque stretch bolts, use new ones.
you don't want the rack coming loose.
- 1295 Views
- 1385 Views
Last post by alschnertz
- 10 Replies
- 3000 Views
Last post by Marni
- 1326 Views
Last post by oragex
- 478 Views
Last post by stevolvos60
