1998 V70 timing belt: number of teeth
5rivers
Year and Model: V70 1998 T5
Been thanked: 15 times
Post by 5rivers »
Greetings all!!
I had the misfortune of having the timing belt on my V70 tear apart while driving on the NYS Thruway about 10 days ago. I did not discover this until a few days of trying other restart measures. But, my problem is this: the old belt that torn apart has 148 teeth; the new belt has 142 teeth. Which belt should I be using on my '98 Volvo V70 base? Appreciate any and all replies!
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
If the old one had 148...then you will need a belt with 148 teeth.I'm affraid that it's not your ONLY concern.
You will need a rebuilt head because there are some bent valves in yours...or to take yours and have it rebuilt.Besides that,there should be a new timing belt kit installed.
Timing belt failure on these cars means GAME OVER,usually just for the head internal components like exhaust and intake valves.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
5rivers
Post by 5rivers »
Yes, I realize there might be more damage. I suppose it would make sense to determine how much damage before replacing the water pump and installing a new timing belt plus pulley's, etc. Would that require removing the head (as there is no other way to see valves, etc inside the motor)?
Regarding the number of teeth on the timing belt, I looked for the engine serial number and could not make out the third digit, so its either 1234533 or 1274533; given the belt my car needs requires 148 teeth, I am surmising that the engine serial number is 1234533, since V70s with a serial number after 1266128 require 142 teeth. The top part of the third digit looks like a 7, but I think its a 3. Does this make sense? Thanks for your reply!
5rivers
Has thanked: 1613 times
Been thanked: 4078 times
KM...see thread below in case you need cylinder head work..
Clearwater in FL will sell you a reworked head for under 600 USd ready to go
(Will post link here)
https://www.matthewsvolvosite.com/forums ... =1&t=69186
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
If you have a hydraulic tensioner you have 148 teeth. If you have a manual spring tensioner you have 142 teeth.
Also if you have distributor cap and leads there's a 99.5% chance it's 148 teeth.
The engine number is also stamped next to number 1 exhaust port on a plate facing upwards. Wipe off the grime and see if you can get a camera/phone set to macro in there.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I have cap and rotor and have a mech tensioner. Later model 98s were fitted with the mech tensioner.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
The car that I am currently rebuilding has a mechanical tensioner and wires, distributor, etc. I believe ALL '98 car have cap and rotor, the break is with the tensioner.
At any rate, there is NO NEED to check for bent valves, they are if the car jumped time.
misha
Post by misha »
Yep....coil packs were introduced in '99 with Denso management.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
KM..active thread on Clearwater option above...please research
