2000 C70T5 drivers window won't operate
Kulu
Year and Model: C70 T5 coupe 2000
Post by Kulu »
Can any one help please.
I have a 2000 C70 2.3 T5 coupe and the driver's window will not operate. I have all the gear and no idea how to trace this problem in the correct manner, I don't want to jump into buying a new door switch when it could be the motor. Has anyone got the best way to begin resolving this problem.
Thanking you all in anticipation.
Kulu
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Chances are it is the switch and not the motor but you can use a voltmeter to test it. The schematics for the car are here:
http://www.volvowiringdiagrams.com/
The pagination is all messed up due to the way they were scanned but they are fairly complete.
Kulu
Post by Kulu »
Cheers Lee, I did take the switch to bits to understand how it works but as I was on a superstore carpark I didn't bother checking it, will check the diagrams and test it later
Been thanked: 4069 times
It's almost certainly the switch Kulu
You might be able to move the plugs from one switch to another and get your driver window working by sacrificing the operation of the other window
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Unfortunately the front and rear plugs have a different profile and can't be swapped.
In UK and other RHD countries there's a unique number for driver's door switch. Also certain C70 years used switch as signal and high current switching occurred in relays; not sure if this happened in 2000MY. Can you apply power directky to window motor to check it?
rubyvette
Year and Model: 2001 C70
Post by rubyvette »
A 4 position switch from an S/V 70 will fit in the hole and accept the wiring plug from the C70. Only the 2 front window switches will work, but that could be an easier piece to find to do the test.
2007 S60R Magic Blue/
2005 S60 2.5 AWD Silver/Black
2001 C70 Coupe HPT black/black 149000 miles
2000 C70 Coupe HPT 132000 miles...SOLD
1994 850 sedan n/a 230000 miles...SOLD
2003 GMC 2500HD Crew Cab
1993 Corvette 40th Anniv Convertible
1960 Corvette
Kulu
Post by Kulu »
It is only a 2 door, the driver's side has a console with c/locking and 2 window switches, the plug cannot be swopped as it is all one piece. Glad aircon is working as it is getting warmer here.
Thanks for all the input on this, I will get to it over the weekend.
rubyvette
Post by rubyvette »
On mine the switch can be removed from the door panel and unplugged from the wiring harness. That harness plug can be inserted into one of the two female receptacles on a 4 door switch. That will make 2 of the 4 switches operational for testing. That 4 door switch will fit in the door panel hole that the original came out of until you find a correct replacement.
1960 Corvette
Kulu
Post by Kulu »
I removed the switch and dismantled it taking note of how the connections are made, cleaned them up and made them so there was more pressure on them, replaced and now only the central locking works. Even the passenger door one does not work now so I suspect the fuse/circuit breaker under the fuses could be the problem, will check it later today
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
You probably fouled up the switch.
Just get a known good one.
