1999 S70 alternator diodes
asummers
Year and Model: many
Post by asummers »
My alternator has seemed to have died yesterday. After putting in a new battery and getting it tested at my local Oreilly, it said the diodes were bad and the regulator was good. Are the diodes something that is built into the replaceable regulator, or internal to the alternator themselves? Trying to figure out if it a complete alternator replace, or something else. Thanks, alan
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
draser
Year and Model: 2005 S60 2.5T
Post by draser »
They're internal to alternator. Did they give you any data or just the verdict?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
To test diodes you would need to fully disassemble the alternator and check each one with a meter OUT OF CIRCUIT. They don't just ALL go bad. Hmm 8-)
Been thanked: 472 times
Post by cn90 »
Checking diodes is an academic challenge etc. In other words, not easy.
The practical thing to do is to get an alternator...
Bosch AL0805X (X = rebuilt) = $150
Bosch AL0805N (N = new) = $210 or so
Herb Goltz
Year and Model: 04& 06 XC70, '12 s60
Been thanked: 3 times
Post by Herb Goltz »
I think you can check for bad diodes by measuring AC voltage across the battery terminals with the car running. I seem to recall that >0.135VAC was an indication that unconverted AC voltage was passing through.
I think you should measure the DC output of the alternator with some load (lights, defroster grid), measure the AC output, and then check for voltage drops on the pos, neg and B+ cables. Report back with your results and people here will help!
2012 s60 t5
2006 XC70
2004 XC70
Even if there is excessive AC component if car still has 14V or more with engine running the battery will continue to charge. You would get some weird electrical gremlins with high level of AC voltage content.
I would throw in a regulator ($45 or so) and see if the mud sticks. Wouldn't hurt to do above tests.
draser
Post by draser »
If you're getting the 14volts across batt posts chances are alternator is okay. Not quite a fan of the alternate component across batt, since each module has it's own power supply regulator and filter - but to an extent. I'd try to find out how many volts does the alternator output, and how much alternate component there is. They might as well be correct, but before spending the money I''d get some detail.
Has thanked: 1505 times
Been thanked: 3818 times
Diodes will usually fail open circuit imhe. You don't get DC or AC component through them in this case.
However, YVMV the detection of rectification protection.
