Courtesy of Mike (precopster)
As these 3 items closely determine coolant temperature they should be OEM. The temp switch may be out of range and can be tested in a pot of water. Here's a table of correct values for the temp switch
0 degrees - 5740 Ohms
10 degrees - 3700 Ohms
20 degrees - 2450 Ohms
40 degrees - 1150 Ohms
80 degrees - 318 Ohms
100 degrees- 184 Ohms
19xx. p80 ECT measurement temperature vs resistance
- Has thanked: 1611 times
- Been thanked: 4072 times
- 1996 Views
- 4403 Views
- 616 Views
Last post by GDavid
- 13 Replies
- 8471 Views
Last post by lifeofgold
- 9 Replies
- 5152 Views
Last post by Ozark Lee
