2002 V70XC Dash failing
EChem
Year and Model: 2002 S80 T6 Anniv Ed
Post by EChem »
Hi all:
My dash guages, displays, and lights are intermittently failing. Sometimes all the lights and displays go dark, tach, speedo, fuel and temp gauges drop to zero or will be stuck at a reading, all display icons may be lit at times, when I shut the car off dash lights may stay on. While driving everything may work normally, then problems occur again. I am thinking a short/loose connection in the wiring. Just wonder if anyone knows the best connection(s) to start looking at before I have to tear off the dash and start checking everything.
Thanks.
Has thanked: 1613 times
Been thanked: 4075 times
First thing to check is ignition switch. Try wiggling the key when the lights go to see if you can get them back
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
If the DIM its failing, repair service is $150 on Ebay. But check the other things first, ignition key, alternator, CEM
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Tin pest, DIM circuit board needs solder reflowed. You can DIY if you have soldering station with a heat gun.
EChem
Post by EChem »
Thanks for the replies. I have wiggled the ignition and it never caused the gauges to come on. Would a problem with the DIM cause all 0f these gauge problems more so that a wiring short or harness connection problem?
vtl
Post by vtl »
All the dash gauges are controlled by microprocessor. If it is dead, the gauges are dead too.
