Hi all:
My dash guages, displays, and lights are intermittently failing. Sometimes all the lights and displays go dark, tach, speedo, fuel and temp gauges drop to zero or will be stuck at a reading, all display icons may be lit at times, when I shut the car off dash lights may stay on. While driving everything may work normally, then problems occur again. I am thinking a short/loose connection in the wiring. Just wonder if anyone knows the best connection(s) to start looking at before I have to tear off the dash and start checking everything.
Thanks.
2002 V70XC Dash failing
First thing to check is ignition switch. Try wiggling the key when the lights go to see if you can get them back
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
If the DIM its failing, repair service is $150 on Ebay. But check the other things first, ignition key, alternator, CEM
EChem
- Year and Model: 2002 S80 T6 Anniv Ed
Thanks for the replies. I have wiggled the ignition and it never caused the gauges to come on. Would a problem with the DIM cause all 0f these gauge problems more so that a wiring short or harness connection problem?
- 11 Replies
- 1689 Views
- 13 Replies
- 2874 Views
Last post by obayha
- 3894 Views
Last post by precopster
- 1525 Views
Last post by frknvgn
- 13 Replies
- 3296 Views
