Hi -
I have been slowly returning working parts to my car since the timing belt came off while driving. I have replaced the water pump and timing belt, but have a question about the secrets of installing a hydrauli tensioner. When I have the timing belt wound around pulleys and gears, there is no space to install the tensioner. I can see the lower bolt hole and part of the upper bolt hole, but how does not move the pulley to gain access to the bolt holes to bolt in the tensioner. In the alternative, I have loosened the timing belt and installed the tensioner, but then there is not enough slack in the belt in wrap it around the gears and pulleys. I am in a conundrum - it you know of any secrets about this issue, please do help me! Many thanks!
1998 V70 Timing belt, cylinder head work 330k miles!
5rivers
- Year and Model: V70 1998 T5
- Been thanked: 15 times
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
5rivers
Yes, I have!
5rivers
- Has thanked: 311 times
- Been thanked: 817 times
Install the tensioner (and its bolts) with the belt off, the belt is the last thing to go on. Then, when everything is all set, release the tensioner.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
There are several posts on timing belt job. Which instruction or MVS write up are you following?5rivers wrote:Hi -
5rivers
There are several I have been referring to (traceystruesoaps is one of them), but there is one in the repair database (the 33-step version for a 98 V70) that I have bookmarked.
5rivers
- Been thanked: 4071 times
We are all pulling for you KM. hope that head is ok.
If I recall I think you have over 300,000 miles on your V70?
- Year and Model: Many Volvos
- Been thanked: 76 times
What will not work is having the plastic spacer installed while you install the timing belt. The spacer has to go on after the belt is in place and the "grenade pin" is pulled. The spacer can be a real bear to get installed but it is somewhat important. The spacer saved my bacon when I had a tensioner fail on my '94.
xHeart
I remember the struggle, and your very pointer during the TB task on 1997 850.Ozark Lee wrote:What will not work is having the plastic spacer installed while you install the timing belt. The spacer has to go on after the belt is in place and the "grenade pin" is pulled. The spacer can be a real bear to get installed but it is somewhat important. The spacer saved my bacon when I had a tensioner fail on my '94.
Thank you Lee!
5rivers
Yes, my '98 Volvo V70 has 321,6xx miles on it!
Thanks, Steve!
It turns out that the little piece under the crankshaft gear that the belt needs to be routed between it and the crankshaft pulley/gear was what I had not noticed until I actually took the belt off again and felt for it. I read a Bay 13 tutorial on removing the tensioner/timing belt/water pump that had mentioned this small piece of steel/metal. I think it was referred to as a "standoff". Then I had to make sure the belt was routed between the bolt retainer for the lower timing belt cover and the crankshaft pulley/gear. I was then able to pull up on the tensioner pulley and route the rest of the belt. Surprisingly, there was room to install the tensioner!!! It looks like I will need to adjust the exhaust pulley by one tooth before pulling out the nail I have holding the tensioner in and doing the "2-revolution" test on the crankshaft pulley/gear to make sure all the marks are aligned.
I am hoping the car will start/run long enough to get it into the driveway! Working on the street is great for catching up the with neighbors but is not my preferred location especially with alternate street parking!
I will keep you all posted on the outcome! Appreciate all your good wishes
Thanks, Steve!
5rivers
- 16 Replies
- 5297 Views
Last post by RickHaleParker
- 5335 Views
Last post by jimmy57
- 2213 Views
Last post by precopster
- 3085 Views
Last post by erikv11
- 5079 Views
Last post by kallekula
