how can a straight six have 2 banks?
chrisjm91
- Year and Model: 95 Volvo 850T5
I have a straight six here with a PO171 lean on bank 1 & PO174 lean on bank 2, and cylinder 4 misfire. I thought only "V" type engines had banks? I raise the rpms and long term fuel trim goes up with it And sitting at idle in parks its reading a 30% load.
bskeels
- Year and Model: 1997 Volvo 960
- Been thanked: 3 times
Typically the bank 1 is the upstream oxygen sensor (before convertor) and the bank 2 is down stream (after convertor), codes for the "V" type engines will state "bank 1 sensor 1 or 2" for upstream and "bank 2 sensor 1 or 2" for a downstream code
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
- Year and Model: Many Volvos
- Been thanked: 76 times
That 6th cylinder could be a problem since your sig indicates an 850 T5.
- Has thanked: 311 times
- Been thanked: 817 times
What car is this for?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
When the engine has two or more front (upstream) catalysts and fuel trim has to be controlled for the groups of cylinders feeding each catalyst, the cylinder groups are known as Bank 1, bank 2, bank 3, etc.
The naming was originally used for V8 and V6 engines where the exhaust manifolds for each side, or bank, had its own oxygen sensor and fuel trim was controlled bank by bank so the catalyst on each side would work best. For in line 6 cylinders it is very common. Cylinders 1,2, and 3 are bank 1 and cylinders 4, 5, and 6 are bank 2. Volvo 6 cylinders from '99 are this way.
Some V12's are 4 banks due to using two separate 6 cylinder engine control modules and 4 upstream catalysts.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Ozark Lee wrote:That 6th cylinder could be a problem since your sig indicates an 850 T5.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
chrisjm91
Thanks for clearing this up for me. Like I said, I thought banks were "sides" of the engine for "V" type engines. But with a straight engine like a straight 6, using 1-3 as bank 1 and 4-6 as bank 2 makes sense.
- 13 Replies
- 4296 Views
Last post by chitownV
- 10 Replies
- 5248 Views
Last post by jonesg
- 870 Views
Last post by volvobro
- 9 Replies
- 1419 Views
Last post by theWIFES_S70
- 725 Views
Last post by Davegoldcanyon
