98 V70 T5 Manual - Low boost on ARD Green Tune
Seaway
Year and Model: 1998 V70 T5 Manual
Post by Seaway »
Car has been been running great on an ARD Green Tune with boost consistent at 16 -17 psi. Two days ago I had a boost spike to about 22 psi, it was the first time I have had a boost spike running this tune. After that spike I am now only hitting 10psi at WOT. No smoke, nothing obviously wrong and the boost holds steady.
I swapped my TCV with a known good one, reset the ECU and there was no change. Still boosts only to 10 psi and holds there. I have no codes, I did not see any loose vacuum hoses (all are silicone) or charge/intercooler hoses (also silicone).
I rebuilt my 16t urbo under 1000 miles ago and installed a new CBV. After the rebuild the car ran great and always hit the targeted boost.
Any ideas?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Is the wastegate operating smoothly?
Seaway
Post by Seaway »
Ozark Lee wrote:Is the wastegate operating smoothly?
How do I check? Unhook the rod and pull, or ?
Post by Ozark Lee »
I would just move the rod with everything hooked up and see if it catches anywhere and make sure the spring pulls it back to all the way closed.
Seaway
Post by Seaway »
I will give that a try when I get a chance, thanks.\
If the wastegate is not closing all the way, what is the prognosis?
Seaway
Post by Seaway »
I guess I should clean the MAF as well? Could be a lean condition making it pull boost? The MAF is only about a year old and I just changed the stock air filter about a month ago.
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
I would not touch that MAF if I were you. Its new. Don't want to damage it with chemicals
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
Seaway
Post by Seaway »
Fair enough, I will leave it alone!
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I lost 3 psi from a slightly loose clamp. Triple check all the hoses.
I second, checking the waste gate action. The rod gets quite rusty and can restrict the movement. I lightly sanded it and put anti-seize to make the operation smoother.
I would also check that the CBV is working okay.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Seaway
Post by Seaway »
mecheng wrote:I lost 3 psi from a slightly loose clamp. Triple check all the hoses.
How do I pressure test the CBV? Just hook up a hose to the CBV and add pressure with a hand pump?
