Howdy, my park brake dash light is visible when I have the key in position I/II. However, when I pull the park brake on, no light shows up. I replaced the e brake cables and shoes myself last summer and passed state inspection and the light was working for awhile. (used awesome DIY - https://www.matthewsvolvosite.com/forums ... ht#p312113 )
Anyone have some attack points? I checked under the car and the cables look fine to me, and the car seems to hold.
Is there something in the center console I can go after, or is this a possible snafu in the wiring from park brake to dash bulb?
2000 V70XC Park Brake dash light
- Year and Model: Many Volvos
- Been thanked: 76 times
The switch is behind the parking brake handle in the center console and that would be the logical place to start.
DrJammer, did you find a fix for this? I am having the same issue except I never replace the e-brake cables or shoes (those components are working fine).
Anyone else have any input on this issue?
DrJammer wrote:Howdy, my park brake dash light is visible when I have the key in position I/II. However, when I pull the park brake on, no light shows up. I replaced the e brake cables and shoes myself last summer and passed state inspection and the light was working for awhile. (used awesome DIY - https://www.matthewsvolvosite.com/forums ... ht#p312113 )
Item (2) is the connector for the parking brake lamp switch , this is under the cover on a 1999 but I think your 2000 is the same
Thanks for the reply. I removed the center console yesterday and that connector was where it should be. From what I saw, when you activate the e-brake, it causes the connector to pull away and stop making contact. When the e-brake is removed, the connection resumes. Is that how it's designed to work? Nothing happened when I pulled the connector. I will be using a volt meter to see if the wire has current.abscate wrote:Item (2) is the connector for the parking brake lamp switch , this is under the cover on a 1999 but I think your 2000 is the same
