1995 850 GLT Transaxle Seal after Axle replacment
galerie
Year and Model: 1995 850 GLT
Post by galerie »
On April 11, I had my right (passenger) CV axle replaced at NTB (never again), anyway, after the replacement, the transaxle seal started leaking. I took it back to them 3 times and they still could not stop the leak... They did say they went to Volvo and got an original seal the last time.
So I take it to a reputable shop, Friday, they replaced the seal and told me that NTB put it in backwards. Well, today it’s still leaking. Does anyone have an idea of why after the new axle is put in, the seal leaks? Could it be that NTB put in the incorrect axle and the end where the seal is it’s not as big?
I’m at my wits end; no one can figure this out.
How does the seal go in, please tell me...The seal has a metal part on one side and rubber on the other. Do you see the metal part or the rubber par when you are looking at it?
Been thanked: 504 times
Post by cn90 »
For a good sealing effect to work:
- Good Volvo OEM seal.
- The axle, look carefully at the exact spot where it makes contact with the seal, it has to be perfectly smooth with no nicks, scratches. The slightest scratch will cause a leak.
Perhaps during axle replacement, they got a cheap axle from local autoparts store with imperfect machining job. Sometimes axle re-mfg place regrinds the axle shaft (where it mates with the seal), causing leak.
galerie
Post by galerie »
thanks, CN90, but how does the seal go in, what side do you see when looking at it from the axle, see pictures, the rubber side or the metal side
rubber side
rubber side
metal side
metal side
phly50
Year and Model: S70 1998
Post by phly50 »
You see the Metal side.
Has thanked: 311 times
Been thanked: 817 times
+1. When you look at an installed seal, you see the metal side, the rubber side with the spring is inside the trans case.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I bought a cheap reman axle from one of the parts stores, O'Reilly I think, and it leaked no matter what seal I put in the transmission. The fix was to replace the axle.
